查看: 10438|回复: 2
[求助] 请问这种情况,需要在哪里加jar包?
发表于 2007-5-7 18:47:55 | 显示全部楼层 |阅读模式
请问这种情况,需要在哪里加jar包?myeclipse程序里,还是C:\Program Files\Apache Software Foundation\Tomcat 5.0\common\lib里面还是哪里?谢谢
HTTP Status 500 -
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
org.apache.jasper.JasperException: The absolute uri: http://java.sun.com/jsp/jstl/core cannot be resolved in either web.xml or the jar files deployed with this application
        org.apache.jasper.compiler.DefaultErrorHandler.jspError(DefaultErrorHandler.java:50)
        org.apache.jasper.compiler.ErrorDispatcher.dispatch(ErrorDispatcher.java:411)
        org.apache.jasper.compiler.ErrorDispatcher.jspError(ErrorDispatcher.java:118)
        org.apache.jasper.compiler.TagLibraryInfoImpl.generateTLDLocation(TagLibraryInfoImpl.java:316)
        org.apache.jasper.compiler.TagLibraryInfoImpl.<init>(TagLibraryInfoImpl.java:147)
        org.apache.jasper.compiler.Parser.parseTaglibDirective(Parser.java:418)
        org.apache.jasper.compiler.Parser.parseDirective(Parser.java:483)
        org.apache.jasper.compiler.Parser.parseElements(Parser.java:1539)
        org.apache.jasper.compiler.Parser.parse(Parser.java:126)
        org.apache.jasper.compiler.ParserController.doParse(ParserController.java:220)
        org.apache.jasper.compiler.ParserController.parse(ParserController.java:101)
        org.apache.jasper.compiler.Compiler.generateJava(Compiler.java:203)
        org.apache.jasper.compiler.Compiler.compile(Compiler.java:470)
        org.apache.jasper.compiler.Compiler.compile(Compiler.java:451)
        org.apache.jasper.compiler.Compiler.compile(Compiler.java:439)
        org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.java:511)
        org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:295)
        org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:292)
        org.apache.jasper.servlet.JspServlet.service(JspServlet.java:236)
        javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
note The full stack trace of the root cause is available in the Apache Tomcat/5.0.28 logs.
发表于 2007-5-7 18:53:14 | 显示全部楼层
发表于 2007-5-7 19:14:56 | 显示全部楼层
放在C:\Program Files\Apache Software Foundation\Tomcat 5.0\common\lib中
GMT+8, 2025-11-5 08:48
