查看: 9170|回复: 3
[咨询] 关于ajax2级下拉框连动的问题
发表于 2007-2-4 20:24:46 | 显示全部楼层 |阅读模式
<!DOCTYPE   HTML   PUBLIC   "-//W3C//DTD   HTML   4.01   Transitional//EN">
  <html>
  <head>
  <title>MyHtml.html</title>
  <meta   http-equiv="Content-Type"   content="text/html;   charset=gb2312"   />
  <meta   http-equiv="keywords"   content="keyword1,keyword2,keyword3">
  <meta   http-equiv="description"   content="this   is   my   page">
  <!--<link   rel="stylesheet"   type="text/css"   href="./styles.css">-->
  </head>
  <script   type="text/javascript">
  function   getResult(stateVal)   {
                  var   url   =   "servlet/SelectCityServlet?state="+stateVal;
                  if   (window.XMLHttpRequest)   {
                                  req   =   new   XMLHttpRequest();
                  }else   if   (window.ActiveXObject)   {
                                  req   =   new   ActiveXObject("Microsoft.XMLHTTP");
                  if(req){
                                  req.open("GET",url,   true);
                                  req.onreadystatechange   =   complete;
                                  req.send(null);
  function   complete(){
                  if   (req.readyState   ==   4)   {
                                  if   (req.status   ==   200)   {
                                                  var   city   =   req.responseXML.getElementsByTagName("city");
                                                  alert(city.length);
                                                  var   str=new   Array();
                                                  for(var   i=0;i<city.length;i++){
        str=city.firstChild.data;
                                                  alert(document.getElementById("city"));
                                                  buildSelect(str,document.getElementById("city"));
  function   buildSelect(str,sel)   {
                  sel.options.length=0;
                  for(var   i=0;i<str.length;i++)   {
                                  sel.options[sel.options.length]=new   Option(str,str)
  function   test(){
                  alert("test");
  </script>
  <body>
  不变的静止内容
  <BR   />
  <BR   />
  <select   name="state"   onChange="getResult(this.value)">
  <option   value="">请选择</option>
  <option   value="zj">浙江</option>
  <option   value="zs">江苏</option>
  </select>
  <select   id="city"></select>
  <BR   />
  <BR   />
  不用重新刷新
  </body>
  </html>
Servlet代码:
  package   com.stephen.servlet;
  import   java.io.IOException;
  import   java.io.PrintWriter;
  import   javax.servlet.ServletException;
  import   javax.servlet.http.HttpServlet;
  import   javax.servlet.http.HttpServletRequest;
  import   javax.servlet.http.HttpServletResponse;
    *   @author   stephen
    *   TODO   To   change   the   template   for   this   generated   type   comment   go   to   Window   -
    *   Preferences   -   Java   -   Code   Style   -   Code   Templates
  public   class   SelectCityServlet   extends   HttpServlet   {
  public   SelectCityServlet()   {
  super();
  public   void   destroy()   {
  super.destroy();
  public   void   doGet(HttpServletRequest   request,   HttpServletResponse   response)
  throws   ServletException,   IOException   {
  response.setContentType("text/xml");
  response.setCharacterEncoding("UTF-8");
  response.setHeader("Cache-Control",   "no-cache");
  String   state   =   request.getParameter("state");
  StringBuffer   sb   =   new   StringBuffer("<state>");
  if   ("zj".equals(state))   {
  sb.append("<city>杭州</city><city>湖州</city>");
  }   else   if   ("zs".equals(state))   {
  sb.append("<city>南京</city><city>扬州</city><city>苏州</city>");
  sb.append("</state>");
  PrintWriter   out   =   response.getWriter();
  out.write(sb.toString());
  out.close();
web.xml
  <servlet>
  <servlet-name>SelectCityServlet</servlet-name>
  <servlet-class>com.stephen.servlet.SelectCityServlet</servlet-class>
  </servlet>
  <servlet-mapping>
    <url-pattern>/servlet/SelectCityServlet</url-pattern>
  </servlet-mapping>
不知道哪里有问题.
发表于 2007-2-5 09:05:10 | 显示全部楼层
        str=city〔i〕.firstChild.data;
这里面原来的 str=city.firstChild.data 改成上面这样就ok了。
注意city后面的 i 两边是中括号。
[ 本帖最后由 adamed 于 2007-2-5 09:26 编辑 ]
发表于 2007-2-5 09:27:05 | 显示全部楼层
你的代码逻辑上还有一点问题。。servlet部分没问题。主要是城市那个select的动态生成有问题。
这里面str只能是最后一个城市。 buildSelect(str,document.getElementById("city"));
之后出现的城市都是一样的,只能是最后一个城市。
代码改成这样就ok了
                                                  alert(city.length);
                                                   var cityselect=document.getElementById("city");
                                                   cityselect.length=1;
                                                         cityselect〔i〕=new Option(str,str);
注意那个中括号这里是全角的,代码中要改成英文的中括号
[ 本帖最后由 adamed 于 2007-2-5 10:48 编辑 ]
 楼主| 发表于 2007-2-5 17:43:49 | 显示全部楼层
谢谢了..我回家调试下..还是这里好..有热心人帮忙,呵呵
GMT+8, 2025-11-5 16:34
