查看: 20218|回复: 1
[讨论] tomcat redeploy 问题
发表于 2007-5-9 20:39:56 | 显示全部楼层 |阅读模式
我再myeclipse 中重发布我的web工程时总出现如下问题请高手指教
信息: Reloading context [/mywap]
2007-5-9 20:35:12 org.apache.catalina.loader.WebappClassLoader loadClass
信息: Illegal access: this web application instance has been stopped already.  Could not load java.net.BindException.  The eventual following stack trace is caused by an error thrown for debugging purposes as well as to attempt to terminate the thread which caused the illegal access, and has no functional impact.
java.lang.IllegalStateException
        at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1245)
        at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1205)
        at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319)
        at com.mysql.jdbc.CommunicationsException.<init>(CommunicationsException.java:155)
        at com.mysql.jdbc.MysqlIO.send(MysqlIO.java:2723)
        at com.mysql.jdbc.MysqlIO.quit(MysqlIO.java:1401)
        at com.mysql.jdbc.Connection.realClose(Connection.java:4882)
        at com.mysql.jdbc.Connection.cleanup(Connection.java:2062)
        at com.mysql.jdbc.Connection.finalize(Connection.java:3369)
        at java.lang.ref.Finalizer.invokeFinalizeMethod(Native Method)
        at java.lang.ref.Finalizer.runFinalizer(Finalizer.java:83)
        at java.lang.ref.Finalizer.access$100(Finalizer.java:14)
        at java.lang.ref.Finalizer$FinalizerThread.run(Finalizer.java:160)
20:35:17,875  WARN Configurator:126 - No configuration found. Configuring ehcache from ehcache-failsafe.xml found in the classpath: jar:file:/D:/javatools/apache-tomcat-5.5.23/webapps/mywap/WEB-INF/lib/ehcache-1.1.jar!/ehcache-failsafe.xml
发表于 2009-4-6 22:56:27 | 显示全部楼层
GMT+8, 2026-11-20 06:59
