查看: 27362|回复: 10
[求助] MyEclipse5.1.1GA版安装后启动不了!
发表于 2007-5-17 01:37:22 | 显示全部楼层 |阅读模式
我在官网下了MyEclipse5.1.1GA一体包,已包含eclipse3.2.1.装好启动时出现错误
日志内容为:
!SESSION 2007-04-26 14:22:44.683 -----------------------------------------------
eclipse.buildId=M20060921-0945
java.version=1.5.0_08
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=zh_CN
Command-line arguments:  -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.core.runtime 2007-04-26 14:22:54.127
!MESSAGE Product com.genuitec.myeclipse.product.ide could not be found.
!ENTRY org.eclipse.osgi 4 0 2007-04-26 14:22:54.187
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: No application id has been found.
        at org.eclipse.core.internal.runtime.PlatformActivator$1.run(PlatformActivator.java:56)
        at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:92)
        at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:68)
        at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400)
        at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:177)
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
        at java.lang.reflect.Method.invoke(Unknown Source)
        at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336)
        at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
        at org.eclipse.core.launcher.Main.run(Main.java:977)
        at org.eclipse.core.launcher.Main.main(Main.java:952)
发表于 2007-5-17 02:20:58 | 显示全部楼层
发表于 2007-5-17 08:58:41 | 显示全部楼层
 楼主| 发表于 2007-5-17 10:52:18 | 显示全部楼层
发表于 2007-5-17 11:03:23 | 显示全部楼层
 楼主| 发表于 2007-5-17 16:45:32 | 显示全部楼层
发表于 2007-5-17 17:35:20 | 显示全部楼层
如果你myeclipse不是在跟目录下运行会有错误产生.把你myeclipse安装文件放在跟目录,一般需要在磁盘跟目录
[ 本帖最后由 eclipse 于 2007-5-17 20:11 编辑 ]
 楼主| 发表于 2007-5-17 20:05:50 | 显示全部楼层
 楼主| 发表于 2007-5-18 09:58:07 | 显示全部楼层
问题已解决
问题已解决,在此感谢每位回帖的朋友.即使办法没有解决问题,但给本人莫大的鼓励,使我感受到美河在线
的朋友的热心,不像其他论坛的人那么冷淡.在此特别感谢斑竹.
我解决问题的方法是:更新了Windows的更新.由于之前另一个出错,我还原了系统,系统的更新比较久,就出现
启动报错的问题.在此希望对新手门有一个借鉴的例子.
发表于 2007-5-18 10:46:59 | 显示全部楼层
我也出现这个问题,不过我从装了就好了,我是放在D:\的
发表于 2009-4-5 17:51:07 | 显示全部楼层
GMT+8, 2026-11-20 06:22
