查看: 12014|回复: 1
[原创] JSF+SPRING+HIBERNATE整合第一季问题!
发表于 2007-8-9 12:02:53 | 显示全部楼层 |阅读模式
 根据大灰狼老师的视频教程进行JSF+SPRING+HIBERANTE整合实践,发现在起先选择导入SUN公司的JSF,最终服务启动有问题找不着登录页即userLogin.faces,若选择MYFACES 1.1.1,刚可以正常启动,但报以下错误,不过不影响实例运行,请大家给分析一下:
2007-8-9 11:40:05 org.apache.catalina.core.AprLifecycleListener lifecycleEvent
信息: The Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\jdk1.5.0_07\bin;C:\Tomcat 5.5\bin
2007-8-9 11:40:06 org.apache.coyote.http11.Http11BaseProtocol init
信息: Initializing Coyote HTTP/1.1 on http-9000
2007-8-9 11:40:06 org.apache.catalina.startup.Catalina load
信息: Initialization processed in 1321 ms
2007-8-9 11:40:06 org.apache.catalina.core.StandardService start
信息: Starting service Catalina
2007-8-9 11:40:06 org.apache.catalina.core.StandardEngine start
信息: Starting Servlet Engine: Apache Tomcat/5.5.23
2007-8-9 11:40:06 org.apache.catalina.core.StandardHost start
信息: XML validation disabled
2007-8-9 11:40:07 org.apache.myfaces.config.FacesConfigurator feedStandardConfig
信息: Reading standard config org/apache/myfaces/resource/standard-faces-config.xml
2007-8-9 11:40:07 org.apache.myfaces.config.FacesConfigurator feedClassloaderConfigurations
信息: Reading config jar:file:/C:/Tomcat 5.5/common/lib/myfaces-all.jar!/META-INF/faces-config.xml
信息: Reading config jar:file:/D:/eclipse/myworkspace/JSHDemo02/WebRoot/WEB-INF/lib/myfaces-all.jar!/META-INF/faces-config.xml
2007-8-9 11:40:07 org.apache.myfaces.config.FacesConfigurator feedContextSpecifiedConfig
信息: Reading config /WEB-INF/faces-config.xml
2007-8-9 11:40:07 org.apache.myfaces.config.FacesConfigurator feedWebAppConfig
2007-8-9 11:40:07 org.apache.myfaces.util.LocaleUtils toLocale
严重: Locale name null or empty, ignoring
2007-8-9 11:40:08 org.apache.myfaces.webapp.StartupServletContextListener initFaces
信息: ServletContext 'D:\eclipse\myworkspace\JSHDemo02\WebRoot\' initialized.
log4j:WARN No appenders could be found for logger (org.apache.commons.digester.Digester.sax).
log4j:WARN Please initialize the log4j system properly.
2007-8-9 11:40:17 org.apache.myfaces.config.FacesConfigurator feedStandardConfig
2007-8-9 11:40:17 org.apache.myfaces.config.FacesConfigurator feedClassloaderConfigurations
2007-8-9 11:40:17 org.apache.myfaces.util.LocaleUtils toLocale
2007-8-9 11:40:18 org.apache.myfaces.webapp.StartupServletContextListener initFaces
信息: ServletContext 'C:\Tomcat 5.5\server\webapps\manager\' initialized.
2007-8-9 11:40:18 org.apache.myfaces.config.FacesConfigurator feedStandardConfig
2007-8-9 11:40:18 org.apache.myfaces.config.FacesConfigurator feedClassloaderConfigurations
2007-8-9 11:40:18 org.apache.myfaces.util.LocaleUtils toLocale
2007-8-9 11:40:19 org.apache.myfaces.webapp.StartupServletContextListener initFaces
信息: ServletContext 'C:\Tomcat 5.5\server\webapps\host-manager\' initialized.
2007-8-9 11:40:19 org.apache.myfaces.config.FacesConfigurator feedStandardConfig
2007-8-9 11:40:19 org.apache.myfaces.config.FacesConfigurator feedClassloaderConfigurations
2007-8-9 11:40:19 org.apache.myfaces.util.LocaleUtils toLocale
信息: ServletContext 'C:\Tomcat 5.5\server\webapps\admin\' initialized.
2007-8-9 11:40:20 org.apache.myfaces.config.FacesConfigurator feedStandardConfig
2007-8-9 11:40:20 org.apache.myfaces.config.FacesConfigurator feedClassloaderConfigurations
2007-8-9 11:40:20 org.apache.myfaces.util.LocaleUtils toLocale
2007-8-9 11:40:20 org.apache.myfaces.webapp.StartupServletContextListener initFaces
信息: ServletContext 'C:\Tomcat 5.5\webapps\ROOT\' initialized.
信息: ServletContext 'C:\Tomcat 5.5\webapps\tomcat-docs\' initialized.
2007-8-9 11:40:21 org.apache.myfaces.util.LocaleUtils toLocale
ContextListener: attributeAdded('org.apache.myfaces.config.RuntimeConfig', 'org.apache.myfaces.config.RuntimeConfig@ce41cc')
ContextListener: attributeAdded('org.apache.myfaces.webapp.webxml.WebXml', 'org.apache.myfaces.webapp.webxml.WebXml@fa3ce5')
ContextListener: attributeAdded('org.apache.myfaces.webapp.StartupServletContextListener.FACES_INIT_DONE', 'true')
2007-8-9 11:40:21 org.apache.myfaces.webapp.StartupServletContextListener initFaces
信息: ServletContext 'C:\Tomcat 5.5\webapps\jsp-examples\' initialized.
2007-8-9 11:40:21 org.apache.catalina.core.ApplicationContext log
信息: ContextListener: contextInitialized()
信息: SessionListener: contextInitialized()
2007-8-9 11:40:21 org.apache.myfaces.config.FacesConfigurator feedStandardConfig
2007-8-9 11:40:21 org.apache.myfaces.config.FacesConfigurator feedClassloaderConfigurations
ContextListener: attributeAdded('org.apache.myfaces.config.RuntimeConfig', 'org.apache.myfaces.config.RuntimeConfig@fe2509')
ContextListener: attributeAdded('org.apache.myfaces.webapp.webxml.WebXml', 'org.apache.myfaces.webapp.webxml.WebXml@131767b')
信息: ServletContext 'C:\Tomcat 5.5\webapps\servlets-examples\' initialized.
2007-8-9 11:40:22 org.apache.myfaces.config.FacesConfigurator feedClassloaderConfigurations
2007-8-9 11:40:22 org.apache.myfaces.util.LocaleUtils toLocale
2007-8-9 11:40:22 org.apache.myfaces.webapp.StartupServletContextListener initFaces
信息: ServletContext 'C:\Tomcat 5.5\webapps\balancer\' initialized.
2007-8-9 11:40:22 org.apache.catalina.core.ApplicationContext log
信息: org.apache.webapp.balancer.BalancerFilter: init(): ruleChain: [org.apache.webapp.balancer.RuleChain: [org.apache.webapp.balancer.rules.URLStringMatchRule: Target string: News / Redirect URL: http://www.cnn.com], [org.apache.webapp.balancer.rules.RequestParameterRule: Target param name: paramName / Target param value: paramValue / Redirect URL: http://www.yahoo.com], [org.apache.webapp.balancer.rules.AcceptEverythingRule: Redirect URL: http://jakarta.apache.org]]
2007-8-9 11:40:22 org.apache.myfaces.config.FacesConfigurator feedStandardConfig
信息: ServletContext 'C:\Tomcat 5.5\webapps\webdav\' initialized.
2007-8-9 11:40:22 org.apache.catalina.core.StandardContext listenerStart
严重: Error configuring application listener of class org.springframework.web.context.ContextLoaderListener
java.lang.ClassNotFoundException: org.springframework.web.context.ContextLoaderListener
        at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1359)
        at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1205)
        at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:3712)
        at org.apache.catalina.core.StandardContext.start(StandardContext.java:4216)
        at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:760)
        at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:740)
        at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:544)
        at org.apache.catalina.startup.HostConfig.deployDirectory(HostConfig.java:920)
        at org.apache.catalina.startup.HostConfig.deployDirectories(HostConfig.java:883)
        at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:492)
        at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1138)
        at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:311)
        at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:120)
        at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1022)
        at org.apache.catalina.core.StandardHost.start(StandardHost.java:736)
        at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1014)
        at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:443)
        at org.apache.catalina.core.StandardService.start(StandardService.java:448)
        at org.apache.catalina.core.StandardServer.start(StandardServer.java:700)
        at org.apache.catalina.startup.Catalina.start(Catalina.java:552)
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
        at java.lang.reflect.Method.invoke(Method.java:585)
        at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:295)
        at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:433)
严重: Skipped installing application listeners due to previous error(s)
2007-8-9 11:40:22 org.apache.catalina.core.StandardContext start
严重: Error listenerStart
严重: Context [/JSHDemo01] startup failed due to previous errors
2007-8-9 11:40:23 org.apache.coyote.http11.Http11BaseProtocol start
信息: Starting Coyote HTTP/1.1 on http-9000
2007-8-9 11:40:23 org.apache.jk.common.ChannelSocket init
信息: JK: ajp13 listening on /0.0.0.0:8009
2007-8-9 11:40:23 org.apache.jk.server.JkMain start
信息: Jk running ID=0 time=0/60  config=null
2007-8-9 11:40:23 org.apache.catalina.storeconfig.StoreLoader load
信息: Find registry server-registry.xml at classpath resource
2007-8-9 11:40:24 org.apache.catalina.startup.Catalina start
信息: Server startup in 17916 ms
