查看: 23781|回复: 5
[转帖] SQLServer和Oracle常用函数对比
发表于 2007-8-10 20:00:51 | 显示全部楼层 |阅读模式
数学函数
  1.绝对值
  S:select abs(-1) value
  O:select abs(-1) value from dual
  2.取整(大)
  S:select ceiling(-1.001) value
  O:select ceil(-1.001) value from dual
  3.取整(小)
  S:select floor(-1.001) value
  O:select floor(-1.001) value from dual
  4.取整(截取)
  S:select cast(-1.002 as int) value
  O:select trunc(-1.002) value from dual
  5.四舍五入
  S:select round(1.23456,4) value 1.23460
  O:select round(1.23456,4) value from dual 1.2346
  6.e为底的幂
  S:select Exp(1) value 2.7182818284590451
  O:select Exp(1) value from dual 2.71828182
  7.取e为底的对数
  S:select log(2.7182818284590451) value 1
  O:select ln(2.7182818284590451) value from dual; 1
  8.取10为底对数
  S:select log10(10) value 1
  O:select log(10,10) value from dual; 1
  9.取平方
  S:select SQUARE(4) value 16
  O:select power(4,2) value from dual 16
  10.取平方根
  S:select SQRT(4) value 2
  O:select SQRT(4) value from dual 2
  11.求任意数为底的幂
  S:select power(3,4) value 81
  O:select power(3,4) value from dual 81
  12.取随机数
  S:select rand() value
  O:select sys.dbms_random.value(0,1) value from dual;
  13.取符号
  S:select sign(-8) value -1
  O:select sign(-8) value from dual -1
  14.圆周率
  S:SELECT PI() value 3.1415926535897931
  O:不知道
  15.sin,cos,tan 参数都以弧度为单位
  例如:select sin(PI()/2) value 得到1(SQLServer)
  16.Asin,Acos,Atan,Atan2 返回弧度
  17.弧度角度互换(SQLServer,Oracle不知道)
  DEGREES:弧度-〉角度
  RADIANS:角度-〉弧度
数值间比较
  18. 求集合最大值
  S:select max(value) value from
  (select 1 value
  union
  select -2 value
  union
  select 4 value
  union
  select 3 value)a
  O:select greatest(1,-2,4,3) value from dual
  19. 求集合最小值
  S:select min(value) value from
  (select 1 value
  union
  select -2 value
  union
  select 4 value
  union
  select 3 value)a
  O:select least(1,-2,4,3) value from dual
  20.如何处理null值(F2中的null以10代替)
  S:select F1,IsNull(F2,10) value from Tbl
  O:select F1,nvl(F2,10) value from Tbl
  21.求字符序号
  S:select ascii('a') value
  O:select ascii('a') value from dual
  22.从序号求字符
  S:select char(97) value
  O:select chr(97) value from dual
  23.连接
  S:select '11'+'22'+'33' value
  O:select CONCAT('11','22')  33 value from dual
23.子串位置 --返回3
  S:select CHARINDEX('s','sdsq',2) value
  O:select INSTR('sdsq','s',2) value from dual
  23.模糊子串的位置 --返回2,参数去掉中间%则返回7
  S:select patindex('%d%q%','sdsfasdqe') value
  Oracle没发现,但是instr可以通过第四个参数控制出现次数
  select INSTR('sdsfasdqe','sd',1,2) value from dual 返回6
  24.求子串
  S:select substring('abcd',2,2) value
  O:select substr('abcd',2,2) value from dual
  25.子串代替 返回aijklmnef
  S:SELECT STUFF('abcdef', 2, 3, 'ijklmn') value
  O:SELECT Replace('abcdef', 'bcd', 'ijklmn') value from dual
  26.子串全部替换
  S:没发现
  O:select Translate('fasdbfasegas','fa','我' ) value from dual
  27.长度
  S:len,datalength
  O:length
  28.大小写转换 lower,upper
  29.单词首字母大写
  S:没发现
  O:select INITCAP('abcd dsaf df') value from dual
  30.左补空格(LPAD的第一个参数为空格则同space函数)
  S:select space(10)+'abcd' value
  O:select LPAD('abcd',14) value from dual
  31.右补空格(RPAD的第一个参数为空格则同space函数)
  S:select 'abcd'+space(10) value
  O:select RPAD('abcd',14) value from dual
  32.删除空格
  S:ltrim,rtrim
  O:ltrim,rtrim,trim
  33. 重复字符串
  S:select REPLICATE('abcd',2) value
  O:没发现
  34.发音相似性比较(这两个单词返回值一样,发音相同)
  S:SELECT SOUNDEX ('Smith'), SOUNDEX ('Smythe')
  O:SELECT SOUNDEX ('Smith'), SOUNDEX ('Smythe') from dual
  SQLServer中用SELECT DIFFERENCE('Smithers', 'Smythers') 比较soundex的差
  返回0-4,4为同音,1最高
日期函数
  35.系统时间
  S:select getdate() value
  O:select sysdate value from dual
  36.前后几日
  直接与整数相加减
  37.求日期
  S:select convert(char(10),getdate(),20) value
  O:select trunc(sysdate) value from dual
  select to_char(sysdate,'yyyy-mm-dd') value from dual
  38.求时间
  S:select convert(char(8),getdate(),108) value
  O:select to_char(sysdate,'hh24:mm:ss') value from dual
39.取日期时间的其他部分
  SATEPART 和 DATENAME 函数 (第一个参数决定)
  O:to_char函数 第二个参数决定
  参数---------------------------------下表需要补充
  year yy, yyyy
  quarter qq, q (季度)
  month mm, m (m O无效)
  dayofyear dy, y (O表星期)
  day dd, d (d O无效)
  week wk, ww (wk O无效)
  weekday dw (O不清楚)
  Hour hh,hh12,hh24 (hh12,hh24 S无效)
  minute mi, n (n O无效)
  second ss, s (s O无效)
  millisecond ms (O无效)
  40.当月最后一天
  S:不知道
  O:select LAST_DAY(sysdate) value from dual
  41.本星期的某一天(比如星期日)
  S:不知道
  O:SELECT Next_day(sysdate,7) vaule FROM DUAL;
  42.字符串转时间
  S:可以直接转或者select cast('2004-09-08'as datetime) value
  O:SELECT To_date('2004-01-05 22:09:38','yyyy-mm-dd hh24-mi-ss') vaule FROM DUAL;
  43.求两日期某一部分的差(比如秒)
  S:select datediff(ss,getdate(),getdate()+12.3) value
  O:直接用两个日期相减(比如d1-d2=12.3)
  SELECT (d1-d2)*24*60*60 vaule FROM DUAL;
  44.根据差值求新的日期(比如分钟)
  S:select dateadd(mi,8,getdate()) value
  O:SELECT sysdate+8/60/24 vaule FROM DUAL;
  45.求不同时区时间
  S:不知道
  O:SELECT New_time(sysdate,'ydt','gmt' ) vaule FROM DUAL;
  -----时区参数,北京在东8区应该是Ydt-------
  AST ADT 大西洋标准时间
  BST BDT 白令海标准时间
  CST CDT 中部标准时间
  EST EDT 东部标准时间
  GMT 格林尼治标准时间
  HST HDT 阿拉斯加?夏威夷标准时间
  MST MDT 山区标准时间
  NST 纽芬兰标准时间
  PST PDT 太平洋标准时间
  YST YDT YUKON标准时间
SQL中的单记录函数
1.ASCII
返回与指定的字符对应的十进制数;
SQL> select ascii('A') A,ascii('a') a,ascii('0') zero,ascii(' ') space from dual;
        A         A      ZERO     SPACE
       65        97        48        32
2.CHR
给出整数,返回对应的字符;
SQL> select chr(54740) zhao,chr(65) chr65 from dual;
ZH C
赵 A
3.CONCAT
连接两个字符串;
SQL> select concat('010-','88888888')||'转23'  高乾竞电话 from dual;
高乾竞电话
010-88888888转23
4.INITCAP
返回字符串并将字符串的第一个字母变为大写;
SQL> select initcap('smith') upp from dual;
UPP
Smith
5.INSTR(C1,C2,I,J)
在一个字符串中搜索指定的字符,返回发现指定的字符的位置;
C1    被搜索的字符串
C2    希望搜索的字符串
I     搜索的开始位置,默认为1
J     出现的位置,默认为1
SQL> select instr('oracle traning','ra',1,2) instring from dual;
INSTRING
        9
6.LENGTH
返回字符串的长度;
SQL> select name,length(name),addr,length(addr),sal,length(to_char(sal)) from gao.nchar_tst;
NAME   LENGTH(NAME) ADDR             LENGTH(ADDR)       SAL LENGTH(TO_CHAR(SAL))
高乾竞            3 北京市海锭区                6   9999.99                    7
7.LOWER
返回字符串,并将所有的字符小写
SQL> select lower('AaBbCcDd')AaBbCcDd from dual;
AABBCCDD
aabbccdd
8.UPPER
返回字符串,并将所有的字符大写
SQL> select upper('AaBbCcDd') upper from dual;
UPPER
AABBCCDD
9.RPAD和LPAD(粘贴字符)
RPAD  在列的右边粘贴字符
LPAD  在列的左边粘贴字符
SQL> select lpad(rpad('gao',10,'*'),17,'*')from dual;
LPAD(RPAD('GAO',1
*******gao*******
不够字符则用*来填满
10.LTRIM和RTRIM
LTRIM  删除左边出现的字符串
RTRIM  删除右边出现的字符串
SQL> select ltrim(rtrim('   gao qian jing   ',' '),' ') from dual;
LTRIM(RTRIM('
gao qian jing
11.SUBSTR(string,start,count)
取子字符串,从start开始,取count个
SQL> select substr('13088888888',3,8) from dual;
SUBSTR('
08888888
12.REPLACE('string','s1','s2')
string   希望被替换的字符或变量
s1       被替换的字符串
s2       要替换的字符串
SQL> select replace('he love you','he','i') from dual;
REPLACE('H
i love you
13.SOUNDEX
返回一个与给定的字符串读音相同的字符串
SQL> create table table1(xm varchar(8));
SQL> insert into table1 values('weather');
SQL> insert into table1 values('wether');
SQL> insert into table1 values('gao');
SQL> select xm from table1 where soundex(xm)=soundex('weather');
XM
weather
wether
14.TRIM('s' from 'string')
LEADING   剪掉前面的字符
TRAILING  剪掉后面的字符
如果不指定,默认为空格符
15.ABS
返回指定值的绝对值
SQL> select abs(100),abs(-100) from dual;
ABS(100) ABS(-100)
      100       100
16.ACOS
给出反余弦的值
SQL> select acos(-1) from dual;
ACOS(-1)
3.1415927
17.ASIN
给出反正弦的值
SQL> select asin(0.5) from dual;
ASIN(0.5)
.52359878
18.ATAN
返回一个数字的反正切值
SQL> select atan(1) from dual;
  ATAN(1)
.78539816
19.CEIL
返回大于或等于给出数字的最小整数
SQL> select ceil(3.1415927) from dual;
CEIL(3.1415927)
              4
20.COS
返回一个给定数字的余弦
SQL> select cos(-3.1415927) from dual;
COS(-3.1415927)
             -1
发表于 2007-8-11 10:16:56 | 显示全部楼层
发表于 2007-8-20 20:42:39 | 显示全部楼层
发表于 2007-8-21 22:27:39 | 显示全部楼层
发表于 2007-10-9 12:26:10 | 显示全部楼层
发表于 2008-3-18 22:39:32 | 显示全部楼层
GMT+8, 2026-11-20 07:37
