查看: 9698|回复: 1
[求助] 以下java程序有什么错误呢?
发表于 2008-3-1 11:25:36 | 显示全部楼层 |阅读模式
import java.sql.*;
public class MSSQLText
public static void main(String args[]) throws SQLException
String str="select * from USER_FILES";
Connection con = null;
//PreparedStatement pre = null;
ResultSet rs = null;
try {
        System.out.println("开始建立连接");
        con = getConnectionL();
        System.out.println("已经建立连接");
//        pre = con.prepareStatement(str,
//                        ResultSet.TYPE_SCROLL_INSENSITIVE,
//                        ResultSet.CONCUR_UPDATABLE);
//        System.out.println("执行!");
rs=((Statement) con).executeQuery(str);
while(rs.next())
System.out.println(rs.getString("Name")+" ");
rs.close();
con.close();
catch(Exception err){
err.printStackTrace(System.out);
public static Connection getConnectionL() {
        String strDriver = "com.sybase.jdbc.SybDriver";
        Connection conn = null;
        String url = "jdbc:sybase:Tds:localhost:4100/DBNAME?charset=eucgb";
        try {
                Class.forName(strDriver).newInstance();
        } catch (Exception e) {
                System.out.println(e.getMessage() + "driver");
        try {
                conn = DriverManager.getConnection(url, "sa", "111111");
        return conn;
 楼主| 发表于 2008-3-1 14:41:51 | 显示全部楼层
GMT+8, 2026-11-20 07:37
