查看: 22394|回复: 13
[求助] FTP上不去,我用的金币换的流量?请帮忙看下
发表于 2009-6-9 15:42:23 | 显示全部楼层 |阅读模式
230 User logged in, proceed.
状态:>          [2009-6-9 15:38:59] 登录成功。
命令:>          [2009-6-9 15:38:59] PWD
                [2009-6-9 15:38:59] 257 "/" is current directory.
状态:>          [2009-6-9 15:38:59] Home directory: /
状态:>          [2009-6-9 15:38:59] 该站点支持 features。
状态:>          [2009-6-9 15:38:59] 该站点支持 XCRC。
状态:>          [2009-6-9 15:38:59] 该站点支持 SIZE。
状态:>          [2009-6-9 15:38:59] 该站点可以续传中断的下载。
命令:>          [2009-6-9 15:38:59] MODE Z
                [2009-6-9 15:39:00] 200 MODE Z ok.
命令:>          [2009-6-9 15:39:00] REST 0
                [2009-6-9 15:39:00] 350 Restarting at 0. Send STORE or RETRIEVE.
命令:>          [2009-6-9 15:39:00] PORT 148,40,26,20,11,138
                [2009-6-9 15:39:00] 200 PORT Command successful.
命令:>          [2009-6-9 15:39:00] LIST
                [2009-6-9 15:39:00] 150 Opening ASCII mode data connection for /bin/ls.
错误:>           [2009-6-9 15:39:21] 无法从数据 socket 读取。Socket 错误 = #10054。
                [2009-6-9 15:39:22] 426 Data connection closed, transfer aborted.
错误:>           [2009-6-9 15:39:22] 接收到无效应答。
软件用的cuteftp8.2
发表于 2009-6-9 15:51:37 | 显示全部楼层
 楼主| 发表于 2009-6-9 16:24:13 | 显示全部楼层
请问有什么需要设置的吗?比如主动被动或者其他??
                *** CuteFTP 8.2 - build Apr  1 2008 ***
状态:>          [2009-6-9 16:22:15] 正在获取列表“”...
状态:>          [2009-6-9 16:22:15] 正在连接到 FTP 服务器... 60.190.222.180:21 (ip = 60.190.222.180)...
状态:>          [2009-6-9 16:22:15] Socket 已连接。正在等候欢迎消息...
                [2009-6-9 16:22:15] 220-BBSFTP Pro- [http://www.ftpse.com/]                 220-Registered [美河学习在线]                 220 Serv-U FTP Server v6.4 for WinSock ready...
状态:>          [2009-6-9 16:22:15] 已连接。正在验证...
命令:>          [2009-6-9 16:22:15] USER eimhe1_一觉醒来
                [2009-6-9 16:22:15] 331 User name okay, need password.[CE]
命令:>          [2009-6-9 16:22:15] PASS *****
                [2009-6-9 16:22:15] 230-(bbsftp v3.6CE) [Cache 277Sec/300Sec Num (7)]                 230 User logged in, proceed.
状态:>          [2009-6-9 16:22:15] 登录成功。
命令:>          [2009-6-9 16:22:15] PWD
                [2009-6-9 16:22:15] 257 "/" is current directory.
状态:>          [2009-6-9 16:22:15] Home directory: /
命令:>          [2009-6-9 16:22:15] FEAT
                [2009-6-9 16:22:16] 仅仅信息消息:
                211-Extension supported
                 CLNT
                 MDTM
                 MDTM YYYYMMDDHHMMSS[+-TZ];filename
                 SIZE
                 SITE PSWD;EXEC;SET;INDEX;ZONE;CHMOD;MSG
                 REST STREAM
                 XCRC filename;start;end
                 MODE Z
                 MLST Type*;Size*;Create;Modify*;Win32.ea*;
                 BBSFTP fileinfo [filename];                  BBSFTP showcr                 211 End
状态:>          [2009-6-9 16:22:16] 该站点支持 features。
状态:>          [2009-6-9 16:22:16] 该站点支持 XCRC。
状态:>          [2009-6-9 16:22:16] 该站点支持 SIZE。
状态:>          [2009-6-9 16:22:16] 该站点可以续传中断的下载。
命令:>          [2009-6-9 16:22:16] MODE Z
                [2009-6-9 16:22:16] 200 MODE Z ok.
命令:>          [2009-6-9 16:22:16] REST 0
                [2009-6-9 16:22:16] 350 Restarting at 0. Send STORE or RETRIEVE.
命令:>          [2009-6-9 16:22:16] PASV
                [2009-6-9 16:22:16] 227 Entering Passive Mode (60,190,222,180,4,43)
命令:>          [2009-6-9 16:22:16] LIST
状态:>          [2009-6-9 16:22:16] 正在连接 FTP 数据 socket... 60.190.222.180:1067...
错误:>           [2009-6-9 16:22:37] 由于错误或超时,连接失败。
                1) 请核实目的 IP 地址是否正确。
                2) 在“全局设置 | 连接”中增加连接超时限制。
                3) 在“站点设置 | 类型”栏中切换为相对的数据连接类型 (PASV 或 PORT)。
                4) 请试着换个服务器连接,以便核实不是本地的问题。
                5) 如果使用了服务器名,请核实是否已解析为正确的地址。
                6) 如果服务器名解析使用了本地服务器表,请检查以确认没有解析为废旧的地址。
                7) 尝试 ping 地址。
                8) 如果您正使用路由器,请核实路由器是否运行正确(ping 路由器,然后 ping 路由器的外部地址)。
                9) 执行到目的地的跟踪程序,以核实所有路由器都延着连接路径运行。
                10) 请核实您的子网掩码设置是否正确。
                11) 请核实您的本地软件或硬件防火墙不拦截来自 CuteFTP 的外出连接源。
                12) 请核实您的杀毒软件没有错误(试着将其禁用)。
错误:>           [2009-6-9 16:22:37] PASV 已失败,正在尝试 PORT。
状态:>          [2009-6-9 16:22:37] 正在等候 0 秒...
状态:>          [2009-6-9 16:22:38] 正在获取列表“/”...
状态:>          [2009-6-9 16:22:38] 正在连接到 FTP 服务器... 60.190.222.180:21 (ip = 60.190.222.180)...
状态:>          [2009-6-9 16:22:38] Socket 已连接。正在等候欢迎消息...
                [2009-6-9 16:22:38] 220-BBSFTP Pro- [http://www.ftpse.com/]                 220-Registered [美河学习在线]                 220 Serv-U FTP Server v6.4 for WinSock ready...
状态:>          [2009-6-9 16:22:38] 已连接。正在验证...
命令:>          [2009-6-9 16:22:38] USER eimhe1_一觉醒来
                [2009-6-9 16:22:38] 331 User name okay, need password.[CE]
命令:>          [2009-6-9 16:22:38] PASS *****
                [2009-6-9 16:22:38] 230-(bbsftp v3.6CE) [Cache 0Sec/300Sec Num (7)]                 230 User logged in, proceed.
状态:>          [2009-6-9 16:22:38] 登录成功。
命令:>          [2009-6-9 16:22:38] PWD
                [2009-6-9 16:22:38] 257 "/" is current directory.
状态:>          [2009-6-9 16:22:38] Home directory: /
状态:>          [2009-6-9 16:22:38] 该站点支持 features。
状态:>          [2009-6-9 16:22:38] 该站点支持 XCRC。
状态:>          [2009-6-9 16:22:38] 该站点支持 SIZE。
状态:>          [2009-6-9 16:22:38] 该站点可以续传中断的下载。
命令:>          [2009-6-9 16:22:38] MODE Z
                [2009-6-9 16:22:38] 200 MODE Z ok.
命令:>          [2009-6-9 16:22:38] REST 0
                [2009-6-9 16:22:38] 350 Restarting at 0. Send STORE or RETRIEVE.
命令:>          [2009-6-9 16:22:38] PORT 148,40,26,20,14,61
                [2009-6-9 16:22:38] 200 PORT Command successful.
命令:>          [2009-6-9 16:22:38] LIST
                [2009-6-9 16:22:38] 150 Opening ASCII mode data connection for /bin/ls.
错误:>           [2009-6-9 16:22:59] 无法从数据 socket 读取。Socket 错误 = #10054。
                [2009-6-9 16:23:00] 426 Data connection closed, transfer aborted.
错误:>           [2009-6-9 16:23:00] 接收到无效应答。
发表于 2009-6-9 16:45:08 | 显示全部楼层
 楼主| 发表于 2009-6-9 17:03:42 | 显示全部楼层
100金币换1G流量啊,呵呵,但是我一直登陆不上去,用了leafftp和cuteftp都不行呵呵。
发表于 2009-6-9 17:18:22 | 显示全部楼层
 楼主| 发表于 2009-6-9 17:28:57 | 显示全部楼层
已经用过两个软件,感觉应该不是软件问题,可能设置上有没有问题,应为我端口什么都是按照默认设置的,就设了IP地址和用户名密码。
看上面的log我能登陆FTP服务器的
发表于 2009-6-9 19:04:41 | 显示全部楼层
 楼主| 发表于 2009-6-9 20:14:02 | 显示全部楼层
找到原因,单位外网机器ftp不正常啊。在家里就好了,谢谢楼上各位
 楼主| 发表于 2009-6-9 22:57:03 | 显示全部楼层
我记得美河原来有很多很好的书的,现在怎么觉得都是视频啦,书呢
发表于 2009-6-10 21:59:56 | 显示全部楼层
原帖由 一觉醒来 于 2009-6-9 22:57 发表
书都改视频了,呵呵,我就喜欢视频,看书头晕!
发表于 2009-7-7 20:04:37 | 显示全部楼层
发表于 2009-7-8 07:28:46 | 显示全部楼层
发表于 2009-7-8 13:04:54 | 显示全部楼层
GMT+8, 2026-11-20 07:34
