楼主 |
发表于 2005-1-26 21:31:44
显示全部楼层
Wed Jan 26 21:29:52 2005 正在连接 video.zsedu.net:554
" m3 V0 d8 o0 f. nWed Jan 26 21:29:52 2005 正在连接 video.zsedu.net [IP=61.142.114.236:554]3 x; y' j% R4 d+ j$ r4 y2 E! `
Wed Jan 26 21:29:52 2005 已连接.
1 I B4 p0 W9 nWed Jan 26 21:29:52 2005 OPTIONS rtsp://video.zsedu.net:554 RTSP/1.0. ~1 H1 I% Q1 d* r% R0 M
Wed Jan 26 21:29:52 2005 CSeq: 1$ F. ] A+ ^# C& C/ _2 J6 G: k
Wed Jan 26 21:29:52 2005 User-Agent: RealMedia Player Version 6.0.9.1235 (linux-2.0-libc6-i386-gcc2.95)
" a" r% D) R& N8 |8 C2 W3 aWed Jan 26 21:29:52 2005 ClientChallenge: 9e26d33f2984236010ef6253fb1887f7
' [, t! x5 D% P& fWed Jan 26 21:29:52 2005 PlayerStarttime: [28/03/2003:22:50:23 00:00]; Y" R- b( `% W; h3 k
Wed Jan 26 21:29:52 2005 CompanyID: KnKV4M4I/B2FjJ1TToLycw==
6 @, d" ]: r7 `' { d% u/ Z0 r& ^Wed Jan 26 21:29:52 2005 GUID: 00000000-0000-0000-0000-0000000000008 d6 ?9 m5 n. l( w8 d) j |9 [0 X
Wed Jan 26 21:29:52 2005 RegionData: 0: T0 U# U- p w3 n4 v
Wed Jan 26 21:29:52 2005 ClientID: Linux_2.4_6.0.9.1235_play32_RN01_EN_586' @& G8 g8 j1 U# ]+ N5 ?: o, s
Wed Jan 26 21:29:52 2005 Pragma: initiate-session) e0 j9 }( i& |2 F
Wed Jan 26 21:29:53 2005 RTSP/1.0 200 OK* m4 H, j4 M0 G, @$ p$ x9 r) y3 m+ p
Wed Jan 26 21:29:53 2005 CSeq: 1
; t: v9 S. a* |Wed Jan 26 21:29:53 2005 Date: Wed, 26 Jan 2005 13:30:20 GMT
% ^) C, }2 b# S$ j2 XWed Jan 26 21:29:53 2005 Session: 1757725-1
0 l# t( ^. x& F! q6 R8 E. Z$ EWed Jan 26 21:29:53 2005 Server: RealServer Version 9.0.2.794 (win32)( z) w1 N/ C! d" n
Wed Jan 26 21:29:53 2005 Public: OPTIONS, DESCRIBE, ANNOUNCE, PLAY, SETUP, GET_PARAMETER, SET_PARAMETER, TEARDOWN
! F, P6 [( J! c" ]$ l! LWed Jan 26 21:29:53 2005 RealChallenge1: 046122a27ffec75b79353900c96e596c
7 g7 R, W6 x+ Q1 t2 v gWed Jan 26 21:29:53 2005 StatsMask: 34 B3 a% v- |* n% } u1 k5 L
Wed Jan 26 21:29:53 2005 DESCRIBE rtsp://video.zsedu.net/newmedia/ ... %D1%A7/3/AVSEQ01.rm RTSP/1.0
' p$ ?* y# o w. M1 B0 K0 gWed Jan 26 21:29:53 2005 CSeq: 2! C) T$ q8 G8 e4 G' d
Wed Jan 26 21:29:53 2005 Accept: application/sdp; e5 E8 B% x. d3 } l, v* i" V
+ `. w; N% L3 G3 e4 O9 g L cWed Jan 26 21:29:53 2005 Bandwidth: 10485800' L/ M4 `7 V, m$ U& M: w
Wed Jan 26 21:29:53 2005 SupportsMaximumASMBandwidth: 10 W C2 w/ X. d4 |! D
Wed Jan 26 21:29:53 2005 GUID: 00000000-0000-0000-0000-000000000000
+ h: t9 }+ r5 O) K% WWed Jan 26 21:29:53 2005 Require: com.real.retain-entity-for-setup
, Q5 B3 V! d; f6 aWed Jan 26 21:29:53 2005 RTSP/1.0 200 OK& I# g+ {% K7 p
/ {* l8 q; ~* C+ ?. V$ J( D9 j9 qWed Jan 26 21:29:53 2005 Date: Wed, 26 Jan 2005 13:30:20 GMT) Q" s/ q8 L9 V. E" B* {; ^& H
Wed Jan 26 21:29:53 2005 Set-Cookie: cbid=fkejcheiijdkgliheorokpnqrrjrptqpefhgkipidgfkgipllnjoounqpolsoqmpcffggmdi;path=/;expires=Thu,31-Dec-2037 23:59:59 GMT# T0 l9 S! F: j3 R0 p, \+ \2 R
Wed Jan 26 21:29:53 2005 vsrc: http://video.zsedu.net:8080/view ... 9skeqE72yxBi9q3g1vb' q. ?, v1 m* n
Wed Jan 26 21:29:53 2005 Last-Modified: Tue, 27 May 2003 02:12:16 GMT; }/ I. A. I t, @6 r- S5 x
Wed Jan 26 21:29:53 2005 Content-base: rtsp://video.zsedu.net/newmedia/ ... D1%A7/3/AVSEQ01.rm/3 j) ~/ E4 q7 c4 L$ C
Wed Jan 26 21:29:53 2005 ETag: 1757725-18 Z) o9 G8 ~0 V0 |& X
Wed Jan 26 21:29:53 2005 Session: 1757725-1/ R5 ?3 E Z# {. D( Q: }" y8 l
Wed Jan 26 21:29:53 2005 Content-type: application/sdp
7 y8 ]& t: V. ^# Y" b7 v9 I4 @* b" [ g) UWed Jan 26 21:29:53 2005 Content-length: 1966
/ K' C* r7 W" z) U# V& MWed Jan 26 21:29:53 2005 v=0% _; @1 ^7 l- f
Wed Jan 26 21:29:53 2005 o=- 1054001536 1054001536 IN IP4
8 @" W2 {$ g; y% c- DWed Jan 26 21:29:53 2005 s=<No title>( k" W+ R- r: n9 N- t
Wed Jan 26 21:29:53 2005 i=<No author> ?002
$ k( i. T0 k& K: f3 XWed Jan 26 21:29:53 2005 t=0 0
$ N7 i5 o" `- \$ uWed Jan 26 21:29:53 2005 a=SdpplinVersion:1610645080
0 _- J2 G5 j6 U5 Y' vWed Jan 26 21:29:53 2005 a=Flags:integer;3' J5 p6 x& p, k i
Wed Jan 26 21:29:53 2005 a=IsRealDataType:integer;12 Y x3 J6 R1 k
Wed Jan 26 21:29:53 2005 a=StreamCount:integer;2
0 @4 |; _# p2 d: M& j2 e( j5 ], D" kWed Jan 26 21:29:53 2005 a=Copyright:buffer;"PzAwMgA="
# H7 j, Y7 ~6 s2 M- zWed Jan 26 21:29:53 2005 a=Abstract:string;""
8 h1 J) ~- `* e. b5 dWed Jan 26 21:29:53 2005 a=Keywords:string;""
" A8 A: [0 c9 kWed Jan 26 21:29:53 2005 a=range:npt=0-0& u* j3 t4 i9 [4 {3 V5 d
Wed Jan 26 21:29:53 2005 m=audio 0 RTP/AVP 101! f1 W% f9 b: l, i" h
Wed Jan 26 21:29:53 2005 b=AS:641 o/ ~8 K8 v B& R* `, P
Wed Jan 26 21:29:53 2005 a=control:streamid=0" U' G5 O1 x$ s8 Y; a+ H
Wed Jan 26 21:29:53 2005 a=range:npt=0-627.8650009 M7 w K4 f' k. k1 S$ \" a
Wed Jan 26 21:29:53 2005 a=length:npt=627.865000
5 c5 M0 e ?% r4 O8 L. ^Wed Jan 26 21:29:53 2005 a=rtpmap:101 x-pn-realaudio/1000
P ^$ T; v R7 ]Wed Jan 26 21:29:53 2005 a=mimetype:string;"audio/x-pn-realaudio"+ Y$ Y$ r, _9 `8 e s# {* }) a9 X Y3 \+ s
Wed Jan 26 21:29:53 2005 a=ActualPreroll:integer;1857
. g) s+ R$ X, V V& @; L# f( `Wed Jan 26 21:29:53 2005 a=AvgBitRate:integer;640837 R) ]3 f- Q: G" \& l
Wed Jan 26 21:29:53 2005 a=AvgPacketSize:integer;930% r! J8 s4 y0 K# M# X' f
Wed Jan 26 21:29:53 2005 a=EndOneRuleEndAll:integer;1! }+ U4 o" ? ~$ Z ^) s4 i, n
Wed Jan 26 21:29:53 2005 a=EndTime:integer;627400
: T1 j! k6 S& z- [& z, RWed Jan 26 21:29:53 2005 a=MaxBitRate:integer;640831 H- F, Z* m- w9 T; m
Wed Jan 26 21:29:53 2005 a=MaxPacketSize:integer;9308 x/ H. i1 h3 q' L. x- G
Wed Jan 26 21:29:53 2005 a=Preroll:integer;37145 g9 N: d( t7 j5 F; @. \, N
Wed Jan 26 21:29:53 2005 a=OpaqueData:buffer;"LnJh/QAFAAAucmE1ZgVj1wAFAAAATgAYAAADogBMvkAAB1Vt9BUHqQAQA6IAugAAAACsRAAArEQAAAAQAAJnZW5yY29vawEDAAAAAAAQAQAAAwgAACUAAAAAAAYABQ=="
- M0 H& T8 Y; `, Z! D; W1 l dWed Jan 26 21:29:53 2005 a=RMFF 1.0 Flags:buffer;"AAIAAgAA"& C' j+ k3 i5 A3 T
Wed Jan 26 21:29:53 2005 a=ASMRuleBook:string;"priority=5,averagebandwidth=64083,PNMKeyFrameRule=T;priority=5,averagebandwidth=0,PNMNonKeyFrameRule=T,OnDepend=\"0\",OffDepend=\"0\";"
/ S% J8 H# j! z- TWed Jan 26 21:29:53 2005 a=intrinsicDurationType:string;"intrinsicDurationContinuous", ^( y6 c9 p& u, j/ o3 J
Wed Jan 26 21:29:53 2005 a=StreamName:string;"Audio Stream"" U& v" y' Z& P# ]* y2 h& h' F
Wed Jan 26 21:29:53 2005 m=video 0 RTP/AVP 1016 s: y9 U' n. h& h9 V
Wed Jan 26 21:29:53 2005 b=AS:286& h) p/ a( Q7 d5 v9 G
Wed Jan 26 21:29:53 2005 a=control:streamid=1
3 g- c. h" F* |) Q! Q) YWed Jan 26 21:29:53 2005 a=range:npt=0-627.400000
" _' v2 u3 |* V" g/ aWed Jan 26 21:29:53 2005 a=length:npt=627.400000
- z9 j" k: T, `* U2 ZWed Jan 26 21:29:53 2005 a=rtpmap:101 x-pn-realvideo/10006 N: O5 ^- j' N+ N J1 [
Wed Jan 26 21:29:53 2005 a=mimetype:string;"video/x-pn-realvideo"9 G$ s, y; N3 H9 h8 z
Wed Jan 26 21:29:53 2005 a=AvgBitRate:integer;2859165 w" h. l8 ^& D6 V7 B" m- \
Wed Jan 26 21:29:53 2005 a=AvgPacketSize:integer;1129; M1 p) P" l& W! S. A) T- ^
Wed Jan 26 21:29:53 2005 a=EndOneRuleEndAll:integer;1) i# S) d! l5 \2 M' W3 a9 C. O
Wed Jan 26 21:29:53 2005 a=MaxBitRate:integer;285916' i" [! w/ `/ E4 B
Wed Jan 26 21:29:53 2005 a=MaxPacketSize:integer;1407/ w- |+ V2 t! ]& x+ A3 E
Wed Jan 26 21:29:53 2005 a=Preroll:integer;2179& v4 A4 o, \: h- H F4 O5 K
Wed Jan 26 21:29:53 2005 a=OpaqueData:buffer;"AAAAJlZJRE9SVjMwAWABIAAMAAAAAAAZAAAACpAwMCAwAkA0LCQ="
/ W/ I; y' }$ @, b; O6 pWed Jan 26 21:29:53 2005 a=RMFF 1.0 Flags:buffer;"AAMAAgAAAAI="
- F0 T! b! Q' \8 AWed Jan 26 21:29:53 2005 a=ASMRuleBook:string;"#($Bandwidth >= 285916),priority=9,averagebandwidth=285916,PNMKeyFrameRule=T;#($Bandwidth >= 285916),OnDepend=\"0\",priority=5,averagebandwidth=0,PNMNonKeyFrameRule=T;#($Bandwidth < 285916),priority=9,timestampdelivery=T,DropByN=T,PNMThinningRule=T;"
9 R0 W% E1 j* \1 h, u+ ?Wed Jan 26 21:29:53 2005 a=intrinsicDurationType:string;"intrinsicDurationContinuous"- Q4 }8 q3 F0 t6 m3 \
Wed Jan 26 21:29:53 2005 a=StreamName:string;"Video Stream"
1 V3 }' T: \* L& s2 w nWed Jan 26 21:29:53 2005 开始接受数据!* n! z; S! ~7 k6 {! _
Wed Jan 26 21:29:53 2005 SETUP rtsp://video.zsedu.net/newmedia/ ... SEQ01.rm/streamid=0 RTSP/1.0
$ p) c8 v( W& E! H, O0 DWed Jan 26 21:29:53 2005 CSeq: 3
! i5 r h0 z: Y) v: L5 R, v' B) k* GWed Jan 26 21:29:53 2005 RealChallenge2: ca1cebd5d873425987543e20b4a17b7401d0a8e3, sd=ced483b7! H8 _% D) j: c
Wed Jan 26 21:29:53 2005 Transport: x-pn-tng/tcp;mode=play& q% Z6 n# p( H" g6 Z. X
Wed Jan 26 21:29:53 2005 If-Match: 1757725-1+ U4 Z. s% y* w4 f/ d5 S
Wed Jan 26 21:29:53 2005 RTSP/1.0 200 OK) _) I1 j2 N. P" d7 R0 I
Wed Jan 26 21:29:53 2005 CSeq: 35 M( A; E6 k' T
Wed Jan 26 21:29:53 2005 Date: Wed, 26 Jan 2005 13:30:21 GMT- O; [; j& Y$ P: U+ Y
Wed Jan 26 21:29:53 2005 Session: 1757725-16 }' Z" l6 ^6 C, a5 P9 r+ \4 Z
Wed Jan 26 21:29:53 2005 Reconnect: true1 @1 z% E* ^+ U9 X/ H# D' }
Wed Jan 26 21:29:53 2005 RealChallenge3: b2f19aa3aebbc25caa97138edd3ebe534f213d09,sdr=b9aca1db
1 d. b. u4 i8 u! u5 n! SWed Jan 26 21:29:53 2005 RDTFeatureLevel: 2
6 J9 n* b- D9 tWed Jan 26 21:29:53 2005 Transport: x-pn-tng/tcp;interleaved=0. J3 S4 M* \& J4 N
Wed Jan 26 21:29:53 2005 SETUP rtsp://video.zsedu.net/newmedia/ ... SEQ01.rm/streamid=1 RTSP/1.0' B, v5 Q5 _# v4 {3 m: y! d& k
Wed Jan 26 21:29:53 2005 CSeq: 4
& E6 P: {/ |, A4 M4 M9 AWed Jan 26 21:29:53 2005 Transport: x-pn-tng/tcp;mode=play
+ k8 h4 Q. C0 \3 xWed Jan 26 21:29:53 2005 Session: 1757725-1
# W, f$ W3 q7 }0 w+ c3 NWed Jan 26 21:29:53 2005 RTSP/1.0 200 OK' h6 {& h- d( V5 y% r, F
9 x" d) L. ~- P+ n& g. ]. }Wed Jan 26 21:29:53 2005 Date: Wed, 26 Jan 2005 13:30:21 GMT; L8 J3 _ ^! m8 j) m
4 v) d) G% D0 t4 g. l) n& UWed Jan 26 21:29:53 2005 RDTFeatureLevel: 2
+ k# S) r7 R- [Wed Jan 26 21:29:53 2005 Transport: x-pn-tng/tcp;interleaved=19 N4 Q3 I$ x6 Q5 i
Wed Jan 26 21:29:53 2005 SET_PARAMETER rtsp://video.zsedu.net/newmedia/ ... %D1%A7/3/AVSEQ01.rm RTSP/1.0
- _3 U" ^' ]' K5 V- \Wed Jan 26 21:29:53 2005 CSeq: 5' c! P3 w- N1 N& Z# `, g* k
Wed Jan 26 21:29:53 2005 Subscribe: stream=0;rule=0,stream=0;rule=1,stream=1;rule=0,stream=1;rule=1
/ b2 }, K7 |7 a1 YWed Jan 26 21:29:53 2005 Session: 1757725-1: N1 d+ _" A: [ [4 m; a
Wed Jan 26 21:29:53 2005 RTSP/1.0 200 OK$ R/ c) n0 c6 V3 ]' ^% L( Y' a
Wed Jan 26 21:29:53 2005 CSeq: 5) f4 T w) h( c' o
Wed Jan 26 21:29:53 2005 Date: Wed, 26 Jan 2005 13:30:21 GMT2 o& U% I; `! U; {
Wed Jan 26 21:29:53 2005 Session: 1757725-1; f0 @' M7 ~: i( T
Wed Jan 26 21:29:53 2005 PLAY rtsp://video.zsedu.net/newmedia/ ... %D1%A7/3/AVSEQ01.rm RTSP/1.0: H! w! e6 K4 {: ^- @" s1 b
Wed Jan 26 21:29:53 2005 CSeq: 6
8 i7 X2 q) \) Q$ i9 RWed Jan 26 21:29:53 2005 Session: 1757725-1
/ }; e& A4 c% gWed Jan 26 21:29:53 2005 Range: npt=0.000-! n' K+ ?& v0 y
Wed Jan 26 21:29:54 2005 RTSP/1.0 200 OK
2 P; W1 i D9 JWed Jan 26 21:29:54 2005 CSeq: 6
2 j% N% s( I/ B! K- Z$ ^6 kWed Jan 26 21:29:54 2005 Date: Wed, 26 Jan 2005 13:30:21 GMT: p w' x2 A6 K) Z/ x& N
Wed Jan 26 21:29:54 2005 RTP-Info: url=rtsp://video.zsedu.net/newmedia/%D1%A7%BF%C6%CA%D3%C6%B5/%C7%E0%C4%EA/%D2%D5%CA%F5/%D6%D0%B9%FA%BB%A8%C4%F1%BB%AD%BD%CC%D1%A7/3/AVSEQ01.rm/streamid=0;seq=0;rtptime=0, url=rtsp://video.zsedu.net/newmedia/%D1%A7%BF%C6%CA%D3%C6%B5/%C7%E0%C4%EA/%D2%D5%CA%F5/%D6%D0%B9%FA%BB%A8%C4%F1%BB%AD%BD%CC%D1%A7/3/AVSEQ01.rm/streamid=1;seq=0;rtptime=0 |
