查看: 15460|回复: 2
老师们,求救啊
发表于 2006-12-9 13:59:41 | 显示全部楼层 |阅读模式
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
javax.servlet.ServletException: Hibernate operation: Could not execute JDBC batch update; bad SQL grammar [insert into admin__ssh (useraddr, username) values (?, ?)]; nested exception is java.sql.BatchUpdateException: Table 'admin.admin__ssh' doesn't exist
        org.apache.struts.action.RequestProcessor.processException(RequestProcessor.java:523)
        org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:421)
        org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:224)
        org.apache.struts.action.ActionServlet.process(ActionServlet.java:1194)
        org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
        javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
        javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
root cause
org.springframework.jdbc.BadSqlGrammarException: Hibernate operation: Could not execute JDBC batch update; bad SQL grammar [insert into admin__ssh (useraddr, username) values (?, ?)]; nested exception is java.sql.BatchUpdateException: Table 'admin.admin__ssh' doesn't exist
        org.springframework.jdbc.support.SQLErrorCodeSQLExceptionTranslator.translate(SQLErrorCodeSQLExceptionTranslator.java:224)
        org.springframework.orm.hibernate3.HibernateAccessor.convertJdbcAccessException(HibernateAccessor.java:424)
        org.springframework.orm.hibernate3.HibernateAccessor.convertHibernateAccessException(HibernateAccessor.java:411)
        org.springframework.orm.hibernate3.HibernateTemplate.execute(HibernateTemplate.java:371)
        org.springframework.orm.hibernate3.HibernateTemplate.save(HibernateTemplate.java:614)
        org.me.SshDAO.save(SshDAO.java:29)
        org.me.struts.action.UserAction.execute(UserAction.java:46)
        org.springframework.web.struts.DelegatingActionProxy.execute(DelegatingActionProxy.java:106)
        org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:419)
note The full stack trace of the root cause is available in the Apache Tomcat/5.5.20 logs.
在ssh整合中,就要出这个异常啊 ,这个是什么意思啊 !数据根本就插不进去啊
发表于 2006-12-9 14:24:08 | 显示全部楼层
晕,好象和我当初出现的错误一样
你用如果的是MySQL的话,你就包Usertable.hbm.xml里标签<id>里的catalog="admin"去掉,把id生成方式最好改成<generator class="uuid.hex"/>
我这样改了后就没有异常了。
 楼主| 发表于 2006-12-9 16:33:15 | 显示全部楼层
