查看: 4010|回复: 1
我在学习log4j时遇到的问题.
发表于 2006-12-11 16:06:21 | 显示全部楼层 |阅读模式
我是strut3.2模式下[配置tomcat5.0+elclipse3.12+myeclipse4.0GA].我练习log4j时.去添加了log4j-1.2.14.然后按视频上配置了资源文件.但是,tomcat启动时却出现了错误.
有会的帮我解决一下啊。
2006-12-11 15:59:40 org.apache.coyote.http11.Http11Protocol init
信息: Initializing Coyote HTTP/1.1 on http-8080
2006-12-11 15:59:40 org.apache.catalina.startup.Catalina load
信息: Initialization processed in 1218 ms
2006-12-11 15:59:41 org.apache.catalina.core.StandardService start
信息: Starting service Catalina
2006-12-11 15:59:41 org.apache.catalina.core.StandardEngine start
信息: Starting Servlet Engine: Apache Tomcat/5.0.28
2006-12-11 15:59:41 org.apache.catalina.core.StandardHost start
信息: XML validation disabled
2006-12-11 15:59:41 org.apache.catalina.core.StandardHost getDeployer
信息: Create Host deployer for direct deployment ( non-jmx )
2006-12-11 15:59:41 org.apache.catalina.core.StandardHostDeployer install
信息: Processing Context configuration file URL file:D:\J2EEProgram\Tomcat 5.0\conf\Catalina\localhost\balancer.xml
信息: Processing Context configuration file URL file:D:\J2EEProgram\Tomcat 5.0\conf\Catalina\localhost\admin.xml
2006-12-11 15:59:42 org.apache.struts.util.PropertyMessageResources <init>
信息: Initializing, config='org.apache.struts.util.LocalStrings', returnNull=true
信息: Initializing, config='org.apache.struts.action.ActionResources', returnNull=true
信息: Initializing, config='org.apache.webapp.admin.ApplicationResources', returnNull=true
2006-12-11 15:59:44 org.apache.catalina.core.StandardHostDeployer install
信息: Processing Context configuration file URL file:D:\J2EEProgram\Tomcat 5.0\conf\Catalina\localhost\manager.xml
信息: Installing web application at context path  from URL file:D:\J2EEProgram\Tomcat 5.0\webapps\ROOT
信息: Installing web application at context path /tomcat-docs from URL file:D:\J2EEProgram\Tomcat 5.0\webapps\tomcat-docs
信息: Installing web application at context path /jsp-examples from URL file:D:\J2EEProgram\Tomcat 5.0\webapps\jsp-examples
信息: Installing web application at context path /servlets-examples from URL file:D:\J2EEProgram\Tomcat 5.0\webapps\servlets-examples
信息: Installing web application at context path /webdav from URL file:D:\J2EEProgram\Tomcat 5.0\webapps\webdav
2006-12-11 15:59:45 org.apache.catalina.core.StandardHostDeployer install
信息: Installing web application at context path /emiheStruts2 from URL file:D:\J2EEProgram\Tomcat 5.0\webapps\emiheStruts2
信息: Installing web application at context path /eimheStrutsLesson2 from URL file:D:\J2EEProgram\Tomcat 5.0\webapps\eimheStrutsLesson2
2006-12-11 15:59:46 org.apache.struts.util.PropertyMessageResources <init>
信息: Initializing, config='org.suda.struts.ApplicationResources', returnNull=true
2006-12-11 15:59:46 org.apache.struts.validator.ValidatorPlugIn initResources
信息: Loading validation rules file from '/WEB-INF/validator-rules.xml'
2006-12-11 15:59:47 org.apache.struts.validator.ValidatorPlugIn initResources
信息: Loading validation rules file from '/WEB-INF/validation.xml'
2006-12-11 15:59:47 org.apache.catalina.core.StandardHostDeployer install
信息: Installing web application at context path /emiheStrut1 from URL file:D:\J2EEProgram\Tomcat 5.0\webapps\emiheStrut1
信息: Installing web application at context path /log4jTest from URL file:D:\J2EEProgram\Tomcat 5.0\webapps\log4jTest
2006-12-11 15:59:48 org.apache.catalina.core.StandardContext start
严重: Error reading tld listeners javax.servlet.ServletException: Exception processing TLD at resource path /WEB-INF/struts-logic.tld in context /log4jTest
        at org.apache.catalina.startup.TldConfig.tldScanTld(TldConfig.java:549)
        at org.apache.catalina.startup.TldConfig.execute(TldConfig.java:301)
        at org.apache.catalina.core.StandardContext.start(StandardContext.java:4282)
        at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:823)
        at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:807)
        at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:595)
        at org.apache.catalina.core.StandardHostDeployer.install(StandardHostDeployer.java:277)
        at org.apache.catalina.core.StandardHost.install(StandardHost.java:832)
        at org.apache.catalina.startup.HostConfig.deployDirectories(HostConfig.java:701)
        at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:432)
        at org.apache.catalina.startup.HostConfig.start(HostConfig.java:983)
        at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:349)
        at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:119)
        at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1091)
        at org.apache.catalina.core.StandardHost.start(StandardHost.java:789)
        at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1083)
        at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:478)
        at org.apache.catalina.core.StandardService.start(StandardService.java:480)
        at org.apache.catalina.core.StandardServer.start(StandardServer.java:2313)
        at org.apache.catalina.startup.Catalina.start(Catalina.java:556)
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
        at java.lang.reflect.Method.invoke(Method.java:585)
        at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:287)
        at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:425)
2006-12-11 15:59:48 org.apache.commons.digester.Digester endElement
严重: End event threw exception
org.apache.commons.logging.LogConfigurationException: org.apache.commons.logging.LogConfigurationException: No suitable Log constructor [Ljava.lang.Class;@6ce26e for org.apache.commons.logging.impl.Log4JLogger (Caused by java.lang.NoClassDefFoundError: org/apache/log4j/Category) (Caused by org.apache.commons.logging.LogConfigurationException: No suitable Log constructor [Ljava.lang.Class;@6ce26e for org.apache.commons.logging.impl.Log4JLogger (Caused by java.lang.NoClassDefFoundError: org/apache/log4j/Category))
        at org.apache.commons.logging.impl.LogFactoryImpl.newInstance(LogFactoryImpl.java:543)
        at org.apache.commons.logging.impl.LogFactoryImpl.getInstance(LogFactoryImpl.java:235)
        at org.apache.commons.logging.impl.LogFactoryImpl.getInstance(LogFactoryImpl.java:209)
        at org.apache.commons.logging.LogFactory.getLog(LogFactory.java:351)
        at org.apache.commons.beanutils.ConvertUtilsBean.<init>(ConvertUtilsBean.java:130)
        at org.apache.commons.beanutils.BeanUtilsBean.<init>(BeanUtilsBean.java:110)
        at org.apache.commons.beanutils.BeanUtilsBean$1.initialValue(BeanUtilsBean.java:68)
        at org.apache.commons.beanutils.ContextClassLoaderLocal.get(ContextClassLoaderLocal.java:80)
        at org.apache.commons.beanutils.BeanUtilsBean.getInstance(BeanUtilsBean.java:78)
        at org.apache.commons.beanutils.ConvertUtilsBean.getInstance(ConvertUtilsBean.java:115)
        at org.apache.commons.beanutils.ConvertUtils.convert(ConvertUtils.java:217)
        at org.apache.commons.digester.CallMethodRule.end(CallMethodRule.java:457)
        at org.apache.commons.digester.Rule.end(Rule.java:276)
        at org.apache.commons.digester.Digester.endElement(Digester.java:1058)
        at org.apache.xerces.parsers.AbstractSAXParser.endElement(Unknown Source)
        at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanEndElement(Unknown Source)
        at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch(Unknown Source)
        at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
        at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
        at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
        at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
        at org.apache.commons.digester.Digester.parse(Digester.java:1548)
        at org.apache.catalina.startup.ContextConfig.defaultConfig(ContextConfig.java:515)
        at org.apache.catalina.startup.ContextConfig.start(ContextConfig.java:623)
        at org.apache.catalina.startup.ContextConfig.lifecycleEvent(ContextConfig.java:216)
        at org.apache.catalina.core.StandardContext.start(StandardContext.java:4290)
Caused by: org.apache.commons.logging.LogConfigurationException: No suitable Log constructor [Ljava.lang.Class;@6ce26e for org.apache.commons.logging.impl.Log4JLogger (Caused by java.lang.NoClassDefFoundError: org/apache/log4j/Category)
        at org.apache.commons.logging.impl.LogFactoryImpl.getLogConstructor(LogFactoryImpl.java:413)
        at org.apache.commons.logging.impl.LogFactoryImpl.newInstance(LogFactoryImpl.java:529)
        ... 50 more
Caused by: java.lang.NoClassDefFoundError: org/apache/log4j/Category
        at java.lang.Class.getDeclaredConstructors0(Native Method)
        at java.lang.Class.privateGetDeclaredConstructors(Class.java:2328)
        at java.lang.Class.getConstructor0(Class.java:2640)
        at java.lang.Class.getConstructor(Class.java:1629)
        at org.apache.commons.logging.impl.LogFactoryImpl.getLogConstructor(LogFactoryImpl.java:410)
        ... 51 more
2006-12-11 15:59:48 org.apache.catalina.startup.ContextConfig defaultConfig
严重: Parse error in default web.xml
        at org.apache.commons.digester.Digester.createSAXException(Digester.java:2540)
        at org.apache.commons.digester.Digester.createSAXException(Digester.java:2566)
        at org.apache.commons.digester.Digester.endElement(Digester.java:1061)
发表于 2006-12-11 16:23:56 | 显示全部楼层
GMT+8, 2026-11-20 07:13
