查看: 19475|回复: 1
[12.29][美河资料发布小组@lqh101517][VTC][Oracle.Performance.Tuning.1Z0-033视频]
发表于 2006-12-29 14:38:34 | 显示全部楼层 |阅读模式
地址:4号FTP  VIP资料下载一区\国外IT资料区
VTC的作者Gavin Powell提供了1Z0-033 Oracle 9i调整(Turning)认证考试,包括基本的调整操作和调整工具。内存调整包括共享池、数据库缓存和其它缓存。通过I/O观察,讨论了数据库的物理文件结构、 tablespaces和block leve的l数据文件。
还有排列、锁定、关闭和等待事件、共享和提供服务进程、状态和SQL代码调整和资源管理等。
另外还有操作系统的调整以及专用对象。学习时只要点击Oracle Performance Tuning (1Z0-033) 的其中一课即可。
教程内容:
Introduction
Welcome
Prerequisites for this Course
About this Course pt. 1
About this Course pt. 2
Oracle Tuning Documentation
What is Performance Tuning?
Who Tunes and What Do They Tune?
The Different Stages of Tuning
Development/Testing/Production
Statistics and Performance Evaluation
Goal Oriented Tuning
Common Problems pt. 1
Common Problems pt. 2
Performance Versus Integrity
Oracle Enterprise Manager (OEM)
Performance Tools
The Alert Log
Process Trace Files
User Trace Files
Setting Up Tracing
TKPROF
Manually Collecting Statistics
STATSPACK and Collecting Statistics
Collecting Statistics in OEM
Introducing the Wait Event Interface
What to Tune
Tuning the Shared Pool
The Shared Pool
Shared Pool Efficiency
Shared Pool and Reserved Shared Pool
Library and Dictionary Cache Hit Ratios
Pinning Objects in the Shared Pool
The Large Pool
Caching Cursors
OEM and the Shared Pool
Performance Views
The Database Buffer Cache
Database Buffer Cache Efficiency
OLTP Versus Data Warehouse
Configure the Database Buffer Cache
Examine the Database Buffer Cache
The Buffer Cache Hit Ratio
Processes and the Buffer Cache
How to Tune Buffer Cache
How Else to Tune Buffer Cache
Free List Contention
Multiple Database Writers and Slaves
Monitor Buffer Cache and Subset Pools
OEM and the Database Buffer Cache
Performance and Metadata Views
Other Buffers
Tuning the Redo Log Buffer
Sizing the Redo Log Buffer
The Java Pool
Configuring Automatic PGA Memory
Configuring Manual PGA Memory
Tuning PGA Memory
Changing SGA Memory Online
SGA_MAX_SIZE
Changing Non SGA Memory Online
Performance Views
Tuning I/O: Physical File Structures
Datafiles/Tablespaces/Objects
Control Files and Recoverability
Distribution of Database Files
Dividing Data Across Tablespaces
Oracle Partitioning
Tablespace Storage Structures
Dictionary Managed Tablespaces
Locally Managed Tablespaces
Finding Tablespace Problems
Redo and Archive Log Files pt. 1
Redo and Archive Log Files pt. 2
Physical Structures in OEM
Performance Views
Metadata Views
Tuning I/O at the Block Level
Segments
Extents and Blocks
The High Water Mark
Reclaiming Unused Space
Row Chaining and Row Migration
Reorganizing Indexes
Detecting Problems With Indexes
Metadata Views
Tuning Sorts
How Does Sorting Work?
Which SQL Code Causes Sorting?
Demonstrating SQL Code Sorting
Sorting in Memory and on Disk
Analyzing Sorting
Minimizing Sorting
Sorting in OEM
Performance Views
Locking Issues
Locking Levels
Types of Contention pt. 1
Types of Contention pt. 2
Types of Locks
Detecting Lock Contention
How to Avoid Locking
Lock Monitoring and Removal in OEM
Performance and Metadata Views pt. 1
Performance and Metadata Views pt. 2
Latches and Wait Events
What is a Latch?
Different Types of Latches
Shared Pool Latches pt. 1
Shared Pool Latches pt. 2
Database Buffer Cache Latches pt. 1
Database Buffer Cache Latches pt. 2
Database Buffer Cache Latches pt. 3
Redo Log Latches
Session Connection Latches
Latch Spins, Misses and Sleeps
Latch Miss Rate
Latch Miss Total Time
What is a Wait Event?
Event Types and TIMED_STATISTICS
Idle Wait Events
Querying Significant Wait Events
Wait Events in an Active Database
Analyzing Significant Wait Events
The Wait Event Interface
The Wait Event Interface in OEM
Performance Views
Shared Servers and Dedicated Servers
Tuning Oracle Net Services
Shared Versus Dedicated Servers
Shared Server Configuration
Oracle Net Manager in OEM
Wait Events and Performance Views pt. 1
Wait Events and Performance Views pt. 2
Statistics
What are Statistics?
The Importance of Realistic Statistics
Statistics and OPTIMIZER_MODE
Statistics and CURSOR_SHARING
CBO Parameters pt. 1
CBO Parameters pt. 2
CBO Parameters pt. 3
Gathering Statistics using ANALYZE
Histograms and the ANALYZE Command
Gathering Statistics using DBMS_STATS
Gathering Statistics using OEM
What is STATSPACK?
Installing and Using STATSPACK
Metadata Views
Applications and Specialized Objects
Database Type Requirements
Oracle Special Storage Structures pt. 1
Oracle Special Storage Structures pt. 2
Applying Storage Structures
Creating BTree and Bitmap Indexes Syntax
Creating BTree and Bitmap Indexes Examples
Creating Index Organized Tables
Creating Clusters
Creating Materialized Views
Oracle Partitioning Methods Syntax
Oracle Partitioning Methods Examples pt. 1
Oracle Partitioning Methods Examples pt. 2
Metadata Views
SQL Code Tuning
Building Efficient SQL Code
Tuning Query Clauses pt. 1
Tuning Query Clauses pt. 2
Tuning Query Clauses pt. 3
Comparisons
Joins
Other Factors pt. 1
Other Factors pt. 2
SQL Code Execution Process
The Optimizer and What It Does
The Internal Machinations of the Optimizer pt. 1
The Internal Machinations of the Optimizer pt. 2
Hints
Types of Hints
Influence the Optimizer pt. 1
Influence the Optimizer pt. 2
Alter Table Scans
Alter Index Scans pt. 1
Alter Index Scans pt. 2
Modify Joins pt. 1
Modify Joins pt. 2
Perform SQL in Parallel
Change Queries and Subqueries
Finding Queries with Problems
EXPLAIN PLAN and the PLAN_TABLE
Autotrace in SQL*Plus
SQL Trace and TKPROF pt. 1
SQL Trace and TKPROF pt. 2
Finding Bad Queries in OEM
Plan Stability and Stored Outlines
Resource Management
The Oracle Resource Manager
Resource Manager Components
Resource Plan Directives
Create Groups and Plans and Allocate
Metadata and Performance Views
The Operating System
Basic Operating System Tuning
Virtual Memory/Paging/Swapping
What Determines I/O Distribution?
Database Function and Methods of Distribution
Oracle Database File Types Distribution
Database Block Size
Resource Consumption in OEM
Conclusion
Wrapping it All Up!
Credits
About the Author
发表于 2006-12-30 09:39:06 | 显示全部楼层
只能说,太谢谢了。。。。
那天,
之后。。。地震断网,所以还是,只能看,不能吃。。
GMT+8, 2026-11-20 06:17
