查看: 7224|回复: 3
[分享] 感谢 adamed 那个小程序已经完成通过了谢谢
发表于 2007-1-25 10:05:51 | 显示全部楼层 |阅读模式
这是一个一对多的程序:struts+hibernate
在adamed的指点下做好了.拿来给大家分享一下.
SQL:create table forum(
id int primary key auto_increment,
name varchar(40)
create table topic(
title varchar(50),
cont varchar(500),
author varchar(40),
time time,
forumid int
create table reponse(
cont varchar(500),
author varchar(40),
time time,
topicid int
alter table topic add constraint fk_id foreign key (forumid) references forum(id);
alter table reponse add constraint fk_tid foreign key (topicid) references topic(id);
直接用myEclipse映射不用动并生成DAO.
FORUMDAO:
package org.hiber;
import java.util.ArrayList;
import java.util.List;
import org.apache.commons.logging.Log;
import org.apache.commons.logging.LogFactory;
import org.hibernate.LockMode;
import org.hibernate.Query;
import org.hibernate.Transaction;
import org.hibernate.criterion.Example;
* Data access object (DAO) for domain model class Forum.
* @see org.hiber.Forum
* @author MyEclipse - Hibernate Tools
public class ForumDAO extends BaseHibernateDAO {
    private static final Log log = LogFactory.getLog(ForumDAO.class);
        //property constants
        public static final String NAME = "name";
    public void save(Forum transientInstance) {
        log.debug("saving Forum instance");
        try {
            getSession().save(transientInstance);
            log.debug("save successful");
        } catch (RuntimeException re) {
            log.error("save failed", re);
            throw re;
        public void delete(Forum persistentInstance) {
        log.debug("deleting Forum instance");
        try {
            getSession().delete(persistentInstance);
            log.debug("delete successful");
            log.error("delete failed", re);
            throw re;
    public Forum findById( java.lang.Integer id) {
        log.debug("getting Forum instance with id: " + id);
        try {
                Transaction tx = getSession().beginTransaction();
            Forum instance = (Forum) getSession()
                    .get("org.hiber.Forum", id);
            tx.commit();
            return instance;
            log.error("get failed", re);
            throw re;
    public List findByExample(Forum instance) {
        log.debug("finding Forum instance by example");
        try {
            List results = getSession()
                    .createCriteria("org.hiber.Forum")
                    .add(Example.create(instance))
            .list();
            log.debug("find by example successful, result size: " + results.size());
            return results;
            log.error("find by example failed", re);
            throw re;
    public List findByProperty(String propertyName, Object value) {
      log.debug("finding Forum instance with property: " + propertyName
            + ", value: " + value);
      try {
         String queryString = "from Forum as model where model."
                                                         + propertyName + "= ?";
         Query queryObject = getSession().createQuery(queryString);
                 queryObject.setParameter(0, value);
                 return queryObject.list();
         log.error("find by property name failed", re);
         throw re;
        public List findByName(Object name) {
                return findByProperty(NAME, name);
    public Forum merge(Forum detachedInstance) {
        log.debug("merging Forum instance");
        try {
            Forum result = (Forum) getSession()
                    .merge(detachedInstance);
            log.debug("merge successful");
            return result;
            log.error("merge failed", re);
            throw re;
    public void attachDirty(Forum instance) {
        log.debug("attaching dirty Forum instance");
        try {
            getSession().saveOrUpdate(instance);
            log.debug("attach successful");
            log.error("attach failed", re);
            throw re;
    public void attachClean(Forum instance) {
        log.debug("attaching clean Forum instance");
        try {
            getSession().lock(instance, LockMode.NONE);
            throw re;
    public List getForumList(){
            String hql="from Forum as f";
            List list=new ArrayList();
            list=getSession().createQuery(hql).list();
            return list;
TopicDAO:
package org.hiber;
import java.util.*;
import java.util.Set;
* Data access object (DAO) for domain model class Topic.
* @see org.hiber.Topic
public class TopicDAO extends BaseHibernateDAO {
    private static final Log log = LogFactory.getLog(TopicDAO.class);
        public static final String TITLE = "title";
        public static final String CONT = "cont";
        public static final String AUTHOR = "author";
    public void save(Topic transientInstance) {
        log.debug("saving Topic instance");
        try {
            throw re;
        public void delete(Topic persistentInstance) {
        log.debug("deleting Topic instance");
        try {
            throw re;
    public Topic findById( java.lang.Integer id) {
        log.debug("getting Topic instance with id: " + id);
        try {
            Topic instance = (Topic) getSession()
                    .get("org.hiber.Topic", id);
            return instance;
            throw re;
    public List findByExample(Topic instance) {
        log.debug("finding Topic instance by example");
        try {
                    .createCriteria("org.hiber.Topic")
            .list();
            return results;
            throw re;
      log.debug("finding Topic instance with property: " + propertyName
      try {
         String queryString = "from Topic as model where model."
         throw re;
        public List findByTitle(Object title) {
                return findByProperty(TITLE, title);
        public List findByCont(Object cont) {
                return findByProperty(CONT, cont);
        public List findByAuthor(Object author) {
                return findByProperty(AUTHOR, author);
    public Topic merge(Topic detachedInstance) {
        log.debug("merging Topic instance");
        try {
            Topic result = (Topic) getSession()
            return result;
            throw re;
    public void attachDirty(Topic instance) {
        log.debug("attaching dirty Topic instance");
        try {
            throw re;
    public void attachClean(Topic instance) {
        log.debug("attaching clean Topic instance");
        try {
            throw re;
    public Set getTopic(Integer id){
                Set set=new HashSet();
                try{
                        ForumDAO forumDao = new ForumDAO();
                        set=forumDao.findById(id).getTopics();
                        //list=(List)forumDao.findById(id).getTopics();
                }catch(Exception e){
                        e.printStackTrace();
                return set;
ReponseDAO:
package org.hiber;
import java.util.HashSet;
* Data access object (DAO) for domain model class Reponse.
* @see org.hiber.Reponse
public class ReponseDAO extends BaseHibernateDAO {
    private static final Log log = LogFactory.getLog(ReponseDAO.class);
    public void save(Reponse transientInstance) {
        log.debug("saving Reponse instance");
        try {
            throw re;
        public void delete(Reponse persistentInstance) {
        log.debug("deleting Reponse instance");
        try {
            throw re;
    public Reponse findById( java.lang.Integer id) {
        log.debug("getting Reponse instance with id: " + id);
        try {
            Reponse instance = (Reponse) getSession()
                    .get("org.hiber.Reponse", id);
            return instance;
            throw re;
    public List findByExample(Reponse instance) {
        log.debug("finding Reponse instance by example");
        try {
                    .createCriteria("org.hiber.Reponse")
            .list();
            return results;
            throw re;
      log.debug("finding Reponse instance with property: " + propertyName
      try {
         String queryString = "from Reponse as model where model."
         throw re;
    public Reponse merge(Reponse detachedInstance) {
        log.debug("merging Reponse instance");
        try {
            Reponse result = (Reponse) getSession()
            return result;
            throw re;
    public void attachDirty(Reponse instance) {
        log.debug("attaching dirty Reponse instance");
        try {
            throw re;
    public void attachClean(Reponse instance) {
        log.debug("attaching clean Reponse instance");
        try {
            throw re;
    public Set getReponseList(int id){
            TopicDAO topDao=new TopicDAO();
            set=topDao.findById(id).getReponses();
            return set;
ShowAction:显示FORUM:
* Generated by MyEclipse Struts
* Template path: templates/java/JavaClass.vtl
package org.bbs.struts.action;
import javax.servlet.http.HttpServletRequest;
import javax.servlet.http.HttpServletResponse;
import org.apache.struts.action.Action;
import org.apache.struts.action.ActionForm;
import org.apache.struts.action.ActionForward;
import org.apache.struts.action.ActionMapping;
import org.bbs.struts.form.ShowForm;
import org.hiber.ForumDAO;
* MyEclipse Struts
* Creation date: 01-24-2007
* XDoclet definition:
* @struts.action path="/show" name="showForm" input="/show.jsp" scope="request" validate="true"
public class ShowAction extends Action {
         * Generated Methods
         * Method execute
         * @param mapping
         * @param form
         * @param request
         * @param response
         * @return ActionForward
        public ActionForward execute(ActionMapping mapping, ActionForm form,
                        HttpServletRequest request, HttpServletResponse response) {
                ShowForm showForm = (ShowForm) form;// TODO Auto-generated method stub
                ForumDAO forumDao=new ForumDAO();
                List forumList=forumDao.getForumList();
                request.setAttribute("forumList", forumList);
                return mapping.findForward("showForum");
ShowTopicAction:显示TOPIC:
import java.util.*;
import org.hiber.TopicDAO;
* MyEclipse Struts
* Creation date: 01-25-2007
* @struts.action validate="true"
public class ShowTopicAction extends Action {
         * Generated Methods
         * Method execute
         * @param mapping
         * @param form
         * @param request
         * @param response
                int id=Integer.parseInt((String)request.getParameter("id"));
                Set set=topDao.getTopic(id);
                request.setAttribute("list", set);
                return mapping.findForward("show");
ShowReponseAction:显示REPONSE
import org.hiber.ReponseDAO;
import org.hiber.Topic;
* MyEclipse Struts
public class ShowReponseAction extends Action {
         * Generated Methods
         * Method execute
         * @param mapping
         * @param form
         * @param request
         * @param response
                ReponseDAO rDao=new ReponseDAO();
                List topList=new ArrayList();
                TopicDAO tDao=new TopicDAO();
                Topic topic=tDao.findById(id);
                Set set=rDao.getReponseList(id);
                request.setAttribute("topic", topic);
show.jsp:
<%@ page language="java" pageEncoding="ISO-8859-1"%>
<%@ taglib uri="http://jakarta.apache.org/struts/tags-bean" prefix="bean"%>
<%@ taglib uri="http://jakarta.apache.org/struts/tags-html" prefix="html"%>
<html>
        <head>
                <title>JSP for ShowForm form</title>
        </head>
        <body>
                <html:form action="/show">
                        <html:submit/><html:cancel/>
                </html:form>
        </body>
</html>
showForum.jsp:
<%@ page language="java" pageEncoding="gbk"%>
<%@ taglib uri="http://struts.apache.org/tags-bean" prefix="bean" %>
<%@ taglib uri="http://struts.apache.org/tags-html" prefix="html" %>
<%@ taglib uri="http://struts.apache.org/tags-logic" prefix="logic" %>
<%@ taglib uri="http://struts.apache.org/tags-tiles" prefix="tiles" %>
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html:html lang="true">
  <head>
    <html:base />
    <title>showForum.jsp</title>
        <meta http-equiv="pragma" content="no-cache">
        <meta http-equiv="cache-control" content="no-cache">
        <meta http-equiv="expires" content="0">
        <meta http-equiv="keywords" content="keyword1,keyword2,keyword3">
        <meta http-equiv="description" content="This is my page">
        <link rel="stylesheet" type="text/css" href="styles.css">
  </head>
  <body>
    <table border=1>
      <tr>
       <td>论坛ID</td><td>论坛名</td>
      </tr>
        <logic:iterate name="forumList" id="list" scope="request">
        <tr>
         <td>
           <bean:write name="list" property="id"/>
         </td>
         <td>
           <html:link href="./showTopic.do?" paramName="list" paramProperty="id" paramId="id"> <bean:write name="list" property="name"/></html:link>
         </td>
         </tr>
        </logic:iterate>
    </table>
  </body>
</html:html>
showTopic.jsp:
  <head>
    <html:base />
    <title>showTopic.jsp</title>
  </head>
  <body>
     <table border=1>
      <tr>
       <td>主题ID</td><td>主题标题</td><td>主题作者</td>
      </tr>
        <logic:iterate name="list" id="list" scope="request">
        <tr>
         <td>
         </td>
         <td>
            <html:link href="./showReponse.do?" paramName="list" paramProperty="id" paramId="id"> <bean:write name="list" property="title"/></html:link>
         </td>
         <td><bean:write name="list" property="author"/></td>
         </tr>
        </logic:iterate>
    </table>
  </body>
</html:html>
showReponse.jsp:
  <head>
    <html:base />
    <title>showReponse.jsp</title>
  </head>
  <body>
    <table border=1>
      <tr>
       <td>主题标题</td><td>主题内容</td><td>主题作者</td>
      </tr>
      <tr>
       <td><bean:write name="topic" property="title"></bean:write></td>
       <td><bean:write name="topic" property="cont"></bean:write></td>
       <td><bean:write name="topic" property="author"></bean:write></td>
      </tr>
      <tr>
       <td>回复时间</td><td>回复内容</td><td>回复作者</td>
      </tr>
        <tr>
         <td>
           <bean:write name="list" property="time"/>
         </td>
         <td>
            <bean:write name="list" property="cont"/>
         </td>
         </tr>
        </logic:iterate>
    </table>
  </body>
</html:html>
发表于 2007-1-25 10:48:24 | 显示全部楼层
发表于 2007-1-25 11:00:40 | 显示全部楼层
发表于 2007-1-25 11:12:45 | 显示全部楼层
GMT+8, 2026-11-20 07:12
