查看: 28914|回复: 8
[讨论] hibernate+mysql中文乱码问题
发表于 2007-4-5 15:56:25 | 显示全部楼层 |阅读模式
hibernate+mysql中文乱码问题怎么解决,急用,谢谢QQ47179640
发表于 2007-4-5 17:07:56 | 显示全部楼层
发表于 2007-4-5 20:24:00 | 显示全部楼层
回复 #3 030101044 的帖子
你说的很对,mysql可以在url里配置,但是,必须使前后台保证字符集一致性
发表于 2007-4-5 20:49:15 | 显示全部楼层
用hql语句的话要加<property name="hibernate.query.factory_class">org.hibernate.hql.classic.ClassicQueryTranslatorFactory</property>
页面传递字符的话用过滤器就搞顶了:
package com.lang.filter;
import java.io.IOException;
import javax.servlet.Filter;
import javax.servlet.FilterChain;
import javax.servlet.FilterConfig;
import javax.servlet.ServletException;
import javax.servlet.ServletRequest;
import javax.servlet.ServletResponse;
import org.apache.log4j.Logger;
* Example filter that sets the character encoding to be used in parsing the
* incoming request
public class SetCharacterEncodingFilter implements Filter {
        private String ecodeing=null;
    private static Logger log = Logger.getLogger(SetCharacterEncodingFilter.class);
* Take this filter out of service.
public void destroy() {
* Select and set (if specified) the character encoding to be used to
* interpret request parameters for this request.
public void doFilter(ServletRequest request, ServletResponse response,
FilterChain chain)throws IOException, ServletException {
request.setCharacterEncoding(ecodeing);
response.setCharacterEncoding(ecodeing);
// 传递控制到下一个过滤器
chain.doFilter(request, response);
public void init(FilterConfig filterConfig) throws ServletException {
        ecodeing=filterConfig.getInitParameter("encoding");
还有tomcat里面的servel.xml中不要忘记设置这个<Connector port="8080" maxThreads="150" minSpareThreads="25" maxSpareThreads="75" enableLookups="false" redirectPort="8443" acceptCount="100" debug="0" connectionTimeout="20000" disableUploadTimeout="true" URIEncoding="GBK" />
发表于 2007-4-5 23:11:10 | 显示全部楼层
其实只要在安装MYSQL的时候把编码设置为GBK,然后把把所有相关的值都改为 GBK ,这样就不会出现乱码了
发表于 2007-4-7 23:05:07 | 显示全部楼层
1。设置过滤器
2。数据库的编码为eucgb(sybase)
3。tomcat配置uricoding为gb2312
发表于 2007-4-7 23:47:20 | 显示全部楼层
发表于 2007-4-16 12:00:25 | 显示全部楼层
1、使用gb2312编码,变更mysql的数据库编码字符集。cmd模式下用mysql --default-character-set=gb2312 -u root -p进入,然后再每个建表语句后增加default character set gb2312;
  重新建立数据表。
  值得注意的地方是:applicationContext.xml中的数据库连接必须设置为<property name="url"><value>jdbc:mysql://localhost/struts?useUnicode=true&characterEncoding=gb2312</value></property>,这样插入的才是正常的中文,否则就是乱码。
  2、在进行数据保存之前进行gb2312到iso8859-1编码的转换,applicationContext.xml中的数据库连接必须设置为<property name="url"><value>jdbc:mysql://localhost/struts</value></property>,这样插入的才是正常的中文,否则就是乱码。
  它们相同的地方是在用jsp进行中文内容填加时,都要进行gb2312到iso8859-1编码的转换:
String name;
name=trans(request.getParameter("name"));
String trans(String chi)
 String result = null;
 byte temp [];
 try
  temp=chi.getBytes("iso-8859-1");
  result = new String(temp);
 catch(java.io.UnsupportedEncodingException e)
  System.out.println (e.toString());
 return result;
String trans(Object chi)
 return trans(chi.toString());
发表于 2007-4-20 13:33:43 | 显示全部楼层
Hibernate3.0不支持中文参数,如果把语句改成参数话形式就可以解决
GMT+8, 2026-11-20 07:13
