查看: 10574|回复: 2
[求助] hibernate
发表于 2007-4-19 09:12:30 | 显示全部楼层 |阅读模式
我看了美河制作的hib视频在onetomany的视频中我在本地的实例总是出现如下的错误
信息: Illegal access: this web application instance has been stopped already.  Could not load java.net.BindException.  The eventual following stack trace is caused by an error thrown for debugging purposes as well as to attempt to terminate the thread which caused the illegal access, and has no functional impact.
java.lang.IllegalStateException
        at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1244)
        at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1204)
        at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319)
        at com.mysql.jdbc.CommunicationsException.<init>(CommunicationsException.java:155)
        at com.mysql.jdbc.MysqlIO.send(MysqlIO.java:2723)
        at com.mysql.jdbc.MysqlIO.quit(MysqlIO.java:1401)
        at com.mysql.jdbc.Connection.realClose(Connection.java:4882)
        at com.mysql.jdbc.Connection.cleanup(Connection.java:2062)
        at com.mysql.jdbc.Connection.finalize(Connection.java:3369)
        at java.lang.ref.Finalizer.invokeFinalizeMethod(Native Method)
        at java.lang.ref.Finalizer.runFinalizer(Finalizer.java:83)
        at java.lang.ref.Finalizer.access$100(Finalizer.java:14)
        at java.lang.ref.Finalizer$FinalizerThread.run(Finalizer.java:160)
Hibernate: insert into customer (cname) values (?)
Hibernate: insert into order (odis, cid) values (?, ?)
2007-4-19 8:52:29 org.apache.catalina.core.StandardWrapperValve invoke
严重: Servlet.service() for servlet addOrders threw exception
org.hibernate.exception.SQLGrammarException: could not insert: [org.eimhe.Order]
        at org.hibernate.exception.ErrorCodeConverter.convert(ErrorCodeConverter.java:70)
        at org.hibernate.exception.JDBCExceptionHelper.convert(JDBCExceptionHelper.java:43)
        at org.hibernate.persister.entity.BasicEntityPersister.insert(BasicEntityPersister.java:1777)
        at org.hibernate.persister.entity.BasicEntityPersister.insert(BasicEntityPersister.java:2178)
        at org.hibernate.action.EntityIdentityInsertAction.execute(EntityIdentityInsertAction.java:34)
        at org.hibernate.engine.ActionQueue.execute(ActionQueue.java:239)
        at org.hibernate.event.def.AbstractSaveEventListener.performSaveOrReplicate(AbstractSaveEventListener.java:240)
        at org.hibernate.event.def.AbstractSaveEventListener.performSave(AbstractSaveEventListener.java:160)
        at org.hibernate.event.def.AbstractSaveEventListener.saveWithGeneratedId(AbstractSaveEventListener.java:95)
        at org.hibernate.event.def.DefaultSaveOrUpdateEventListener.saveWithGeneratedOrRequestedId(DefaultSaveOrUpdateEventListener.java:184)
        at org.hibernate.event.def.DefaultSaveEventListener.saveWithGeneratedOrRequestedId(DefaultSaveEventListener.java:33)
        at org.hibernate.event.def.DefaultSaveOrUpdateEventListener.entityIsTransient(DefaultSaveOrUpdateEventListener.java:173)
        at org.hibernate.event.def.DefaultSaveEventListener.performSaveOrUpdate(DefaultSaveEventListener.java:27)
        at org.hibernate.event.def.DefaultSaveOrUpdateEventListener.onSaveOrUpdate(DefaultSaveOrUpdateEventListener.java:69)
        at org.hibernate.impl.SessionImpl.save(SessionImpl.java:481)
        at org.hibernate.impl.SessionImpl.save(SessionImpl.java:476)
        at org.eimhe.ODAO.save(ODAO.java:10)
        at org.eimhe.addOrders.doGet(addOrders.java:54)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
        at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
        at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:228)
        at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
        at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
        at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:104)
        at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
        at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:216)
        at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:844)
        at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:634)
        at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:445)
        at java.lang.Thread.run(Thread.java:595)
Caused by: com.mysql.jdbc.exceptions.MySQLSyntaxErrorException: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'order (odis, cid) values ('aaa', null)' at line 1
        at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:936)
        at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:2941)
        at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:1623)
        at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:1715)
        at com.mysql.jdbc.Connection.execSQL(Connection.java:3249)
        at com.mysql.jdbc.PreparedStatement.executeInternal(PreparedStatement.java:1268)
        at com.mysql.jdbc.PreparedStatement.executeUpdate(PreparedStatement.java:1541)
        at com.mysql.jdbc.PreparedStatement.executeUpdate(PreparedStatement.java:1455)
        at com.mysql.jdbc.PreparedStatement.executeUpdate(PreparedStatement.java:1440)
        at org.hibernate.persister.entity.BasicEntityPersister.insert(BasicEntityPersister.java:1759)
        ... 29 more
请指教
发表于 2007-4-20 13:24:00 | 显示全部楼层
发表于 2007-5-4 13:56:17 | 显示全部楼层
GMT+8, 2026-11-20 07:12
