查看: 16596|回复: 1
[原创] C & Visual Age C++的安装文档
发表于 2007-4-26 11:38:45 | 显示全部楼层 |阅读模式
一、概述.............................................. 1
二、C & Visual Age C++的安装.......................... 1
三、License Server的配置............................. 2
四、测试方法.......................................... 5
4.1 C编译器的测试................................ 5
4.2 C++编译器的测试............................... 6
4.3 Visual Age C++ 图形界面的启动................. 6
一、概述
本手册内容包括C和Visual Age C++的安装,以及License Server的配置,最后是测试方法。
使用root身份登录系统,将光盘放入光驱,C for AIX只有一张光盘,而Visual Age C++有两张盘,放第一张盘。使用命令:
#smitty install_latest
选择安装介质为/dev/cd0
Install and Update from LATEST Available Software
Type or select values in entry fields.
Press Enter AFTER making all desired changes.
[Entry Fields]
* INPUT device / directory for software /dev/cd0
* SOFTWARE to install [_all_latest] +
PREVIEW only? (install operation will NOT occur) no +
COMMIT software updates? yes +
SAVE replaced files? no +
AUTOMATICALLY install requisite software? yes +
EXTEND file systems if space needed? yes +
OVERWRITE same or newer versions? no +
VERIFY install and check file sizes? no +
Include corresponding LANGUAGE filesets? yes +
DETAILED output? no +
Process multiple volumes? yes +
提交安装光盘上所有软件
三、License Server的配置
步骤一:
使用命令增加C/C++的访问路径:#/usr/vac/bin/replaceCSET (C V5.02,V6.0版本已经取消该命令,可以在/etc/environment文件加入C/C++路径。)
运行命令:
#/var/ifor/i4config (AIX4.3.3)
#/usr/opt/ifor/bin/i4config (AIX5L)
步骤二:
From a License Management point of view,
you can choose to configure this system as:
1) Network License Client
2) Nodelock License Server (and/or Network License Client)
3) Network (and/or Nodelock) License Server
4) Central Registry (and/or Network and/or Nodelock) License Server (*)
(*) Remember that one and only one Central Registry License Server (i4gdb daemoe
in a Licensing domain.
Please indicate your choice [1,2,3,4]: 2
选择2
步骤三:
Do you want to disable remote administration of this Nodelock License
Server? [y,n]: y
选择y
步骤四:
You have to choose now which mechanism must be enabled
to locate this License Server:
1) NCS Namespace and Direct Binding (*)
2) Direct Binding only
(*) WARNING: Modifying NCS Namespace configuration may affect
any other application that use NCS on this system.
NCS Namespace is necessary to support old Netls, iFOR/LS Clients.
Please indicate your choice [1,2]: 2
选择2
步骤五
The Administration tool usually uses port number [12999] to locate the
Nodelock License Servers. If for some reason your environment can not use port [12999],
or you want to modify a previously assigned port number you can do it now.
Do you want to change the Nodelock License Server ip port number? [y,n]: n
选择n
步骤六
Choose the desired Server(s) logging level
1) Default
2) All
3) Customized
Please indicate your choice [1,2,3]: 1
选择1
步骤七
The default Log file(s) path is /var/ifor
Enter blank to accept default or specify a new path:
直接回车
步骤八
Server configuration is complete.
Do you want to modify the list of remote Nodelock and/or Network License Servers
this system can connect to in direct binding mode (both for
Administration purposes and for working as Network License Client) ? [y,n]: n
选择n
步骤九
Do you want the License Server(s) automatically start on this system
at boot time? [y,n]: y
选择y
步骤十
WARNING: Configuration is about to end.
This is your last chance to quit before your updates will be written.
Do you want to continue? [y,n]: y
选择y
步骤十一
*** Configuration file updated. ***
Do you want the License Server(s) start now? [y,n]: y
选择y
屏幕显示
0513-059 The i4llmd Subsystem has been started. Subsystem PID is 21776.
'Start Services' has completed successfully
* Configuration completed successfully *
步骤十二
Visual Age C++中包括C语言,下面两个命令都需要做。
C for AIX:
运行命令:
AIX V4.3.3操作系统:
#/var/ifor/i4blt -a -f /usr/vac/cforaix_cn.lic -R root -T 10
AIX 5L操作系统:
#/usr/opt/ifor/bin/i4blt -a -f /usr/vac/cforaix_cn.lic -R root -T 10
Visual Age C++:
运行命令:
AIX V4.3.3操作系统:
#/var/ifor/i4blt -a -f /usr/vacpp/vacpp_cn.lic -R root -T 10
AIX 5L操作系统:
#/usr/opt/ifor/bin/i4blt -a -f /usr/vacpp/vacpp_cn.lic -R root -T 10
屏幕显示:
i4blt Version 4.5.1 AIX -- LUM Basic License Tool
(c) Copyright 1995-1998, IBM Corporation, All Rights Reserved
US Government Users Restricted Rights - Use, duplication or disclosure
restricted by GSA ADP Schedule Contract with IBM Corp.
(c) Copyright 1991-1998 Gradient Technologies Inc., All Rights Reserved
(c) Copyright 1991,1992,1993, Hewlett-Packard Company, All Rights Reserved
ADM-10099: Product successfully enrolled
配置完成
四、测试方法
通过编译程序文件的方式来测试编译器是否正常工作。
4.1 C编译器的测试
执行如下命令:
#cd /tmp
#vi testc.c
testc.c内容如下:
#include
main()
printf(“\nTesting C…OK!\n\n”);
编译testc.c
#cc testc.c -o test
生成可执行文件testc(通过ls命令可以看到)
运行 testc
#./testc
屏幕输出
Testing C… OK!
说明C程序编译正确。
4.2 C++编译器的测试
执行如下命令:
#cd /tmp
#vi testcpp.C
testcpp.C内容如下:
#include
void main()
cout<<“\nTesting C++…OK!\n\n”;
编译testcpp.C
#make testcpp
生成可执行文件testcpp(通过ls命令可以看到)
运行 testcpp
#./testcpp
屏幕输出
Testing C++… OK!
说明C++程序编译正确。
在CDE的command窗口中执行命令
#/usr/vacpp/bin/vacide
图形界面出现并无报错即可
补充:
# /var/ifor/i4blt –s –l cn看看注册成功否?
另外,修改/usr/vac/cforaix_cn.lic文件,第一句话的最后一部分"admin_name"
不要改为root,而是改为 * ,提交以后其他用户编译就不会出现提示了
发表于 2007-4-28 17:57:17 | 显示全部楼层
GMT+8, 2026-11-20 07:12
